99 Slave Cylinder
Old Jan 7, 2008 | 04:30 AM
Brice's Avatar
Brice
Default 99 Slave Cylinder
My clutch is baddly slipping. (I've got a 99 C5)
(spirited driving)
I've just order a textralia Z grip clutch from Chris @ eastcoastsupercharging.com
I'm living in France, so I want to be sure to have all the parts I need to do the swap.
Here is my questions :
I need a Slave Cylinder and Pilot Bearing
-Will the LS6 Slave Cylinder fit my 99 LS1 ?
(part #89059282)
(#14061685 – Pilot Bearing)
-Do I need a Master cylinder ? (my odometer is 51000 miles)
Old Jan 7, 2008 | 04:38 AM
Brice's Avatar
Brice
damned the pilot bearing # are listed as Pilot bearing Pilot bearing, all, w/6.2l, diesel 1984 - 1991.
does the fit our cars?
Old Jan 7, 2008 | 09:15 AM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Both of your part numbers are correct and will work. I usually include the master in all of my clutch kits/install. I would recommend it but it is also something you can do later if you wish unless of course it is bad now.
To 99 Slave Cylinder
