Anyone have a tutorial on installing SS brake lines?
Old Jan 7, 2008 | 03:11 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Default Anyone have a tutorial on installing SS brake lines?
I'd like to have a vague idea of what i'm about to dive in to.
Old Jan 7, 2008 | 10:24 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Not really a big deal. Just get a big open oil type pan to collect all of the brake fluid.
You'll need some flared wrenches and sockets. If the lines are really tight use some PB Blaster.
Crack open both sides of the line and then remome and install the line portion that goes to the body and then the caliper.
Bleed the brakes and you done. Now would be a great time to add some speed bleeders and Motul RBF 600 brake fluid.
Old Jan 7, 2008 | 11:21 PM
DefenderC5's Avatar
DefenderC5
I did the SS lines when I swapped my calipers/rotors. It's pretty straight forward. Just remember the longer two of the four go in the rear. I didn't notice too much of a difference in every day braking response. However, HARD braking was easier to modulate.
Old Jan 8, 2008 | 06:06 AM
BrandonAGr's Avatar
BrandonAGr
I am about to do this myself, been looking around and haven't found any tutorials/guides but most people seem to say its fairly easy.
I plan on repainting the calipers while doing it, what's the best way to block off the line so that it doesn't drain all the brake fluid out while it's disconnected?
Old Jan 8, 2008 | 09:07 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
The longer ones go in front and the shorter ones go in rear, you had it backwards. You need longer ones in the front to turn (movement) whereas the in the rear they are stationary.
Old Jan 8, 2008 | 09:08 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
You can use some vaccum caps.
Old Jan 8, 2008 | 10:21 AM
B-Vette's Avatar
B-Vette
I'm planning on doing mine too. I'm going with the "Goodridge" ss brand and you can buy the optional quick bleeders as well.
On a side note: It is a good time to paint your calipers too. I did mine backwards and had them painted first - glassbleed, powder coated and clear coated. Went with the same color as my car, pewter and it turned out really good!
Old Jan 8, 2008 | 10:28 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
The best Brake lines (goodridge) are from VBP. They eliminate the old blocks on the back and allow you to adjust the hoses better so that they won't rub.
http://www.vbandp.com/detail.aspx?ID=75
Old Jan 8, 2008 | 10:38 AM
vsocks1's Avatar
vsocks1
I bought these Goodridge from LAPD:
http://www.thelapd.com/index.php?mai...roducts_id=167
Old Jan 8, 2008 | 10:43 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I'm going to do mine as well!
I'll check this out and do them soon!
Thanks for your inputs on the lines and doing it right!
Thanks,Matt
Old Jan 8, 2008 | 10:47 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
They are the ones not to get, as they have the block ends that do not allow you to adjust the steel lines to avoid contact with the rims and other suspension parts.
Old Jan 8, 2008 | 10:52 AM
vsocks1's Avatar
vsocks1
Really? Now I wonder if I should try and send them back....haven't installed them yet.
Old Jan 8, 2008 | 10:55 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
I would. Click on the other link, that I posted above and you'll see the difference in the end pieces (elbows) instead of blocks. This allows you position the steel brake lines correctly.
Old Jan 8, 2008 | 12:57 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
For those of you who installed them already: Have you felt a significant difference in braking?
Old Jan 8, 2008 | 01:00 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Pedal travel is reduced and feels firmer. To improve braking you need better pads and rotors. Most important is your tire choice as this your only contact point.
You can not stop any faster than your tires allow. Keep in mind that if you are activating your ABS you are already at your limit.
Old Jan 8, 2008 | 07:23 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
This is part of an brake system upgrade I want to do in late Jan. R1 concepts D/S rotors, Hawk HPS pads and Goodridge SS braided lines.
Old Jan 8, 2008 | 08:26 PM
XXXLTRP's Avatar
XXXLTRP
S#@T! I have mine wrong then. I read elsewhere to put the longer ones in the rear, no instructions were included. The difference is only about an inch or so, they were so close that I had to lay them side by side to tell. I found that even the "short" ones significantly longer than the stock lines front and rear.
To Anyone have a tutorial on installing SS brake lines?
Old Jan 8, 2008 | 08:36 PM
Jason's Avatar
Jason
CI 4-5-6-7 Veteran
You won't notice much in day-to-day use. Where you will notice it is in repeated, hard braking, when the fluid starts to heat up, the rubber lines would get soft and expand when the brakes were applied, this would require more pedal application than normal to achieve the same braking force at the pads. The SS lines won't expand when heated.
Old Jan 8, 2008 | 11:15 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
I'm guessing for a daily driver, there's not much of a reason for them. I can put the extra $$ towards the rotors and pads.
Old Jan 8, 2008 | 11:39 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
It is a great investment and the improvement in the brake pedal feel is awesome.
Rubber lines expand whereas steel ones do not.
