How to fill the automatic trans??
Thanks! I am almost ready to re-intall the new converter and take it to the tuner.
1] Start the engine and allow the engine to idle until the transmission fluid temperature has reached the value specified.
2] Depress the brake pedal and move the shift lever through the gear ranges, pausing a few seconds in each range. Return the shift lever to the PARK range.
3] Raise the vehicle on a hoist. The vehicle must be level with the engine running and the shift lever in the PARK range. Refer to Lifting and Jacking the Vehicle in General Information.
Caution
The engine must be running when the transmission fluid fill plug is removed, or excessive fluid loss will occur. Transmission fluid may be hot. Since the actual fluid level is unknown, stand clear when removing the fill plug. Have a container ready to capture any lost fluid. Do not turn the engine off with the fill plug removed, as you can be injured by hot transmission fluid being expelled out of the oil fill opening.
4] Remove the transmission plug.
Important
The transmission fluid may darken with normal use and does not always indicate contamination or oxidation.
5] Check the fluid color. If necessary, use a small screwdriver as a dipstick.
6] Fill it until it begins to dribble out of the drain plug hole.
FYI MM6/M12:
Fill plug is about halfway up the driver's side of the trans. You should fill it until it starts to dribble out of the fill hole. Note - the pressure sensor is the plug in the Z06.
Many people fill it with a hand crank oil pump thru the drain hole. I initially filled it by the cooler return line at the radiator and adjusted as required.
Either way, look out for the HOT exhaust pipe next to the drain plug.
Fill the tranny up with the fill hole as shown above before starting the car. Then start it and let it run for a short period just to suck up the fluid you have in the pan, probably about 10-15 seconds, and then shut it back off, and add some more fluid. Keep doing this until you can't add anymore with the motor off. Then you can start it and let it run while you fill it the rest of the way up and let it warm up. Shift thru the gears too, leaving your foot on the brake. You don't need to spin the rear wheels.
I think it takes about 12 quarts (Without looking in the book).
