78 mm fast - mamo ported
Old Jan 8, 2008 | 07:47 PM
russellnewnham's Avatar
russellnewnham
Default 78 mm fast - mamo ported
How much is a 78 mm fast mamo ported manifold worth? I am thinking about selling mine and upgrading to 90 mm as I am going to put a much larger cam in. It has been on the car for about 4000 miles.
Old Jan 8, 2008 | 08:45 PM
Tony Mamo @ AFR's Avatar
0Tony Mamo @ AFR
Former Vendor
Russ...
Your ported 78mm FAST will make 5 HP more than an out of the box 90mm....unless you port the 90 as well you will be going backwards. You will only see a 5 RWHP bump in power with the 90mm ported but your throttle response will improve dramatically.
When the smoke clears on the dyno however, the difference between one of my ported 78 units and ported 90's isn't very much. There is probably a better way to allocate those funds IMO....your going to spend alot of money for 5 ponies or so (ported 90 mm intake plus ported LS2 90mm TB, etc.).
My original 346 build made 475 RWHP with the ported 78 FAST....480 with the addition of the larger 90mm unit.
If your starting from scratch I feel the 90 is a good move....but already invested in a ported 78 its probably not unless you simply have to have every last pony and are willing to pay for it (or have a buyer giving you a decent buck for your original set-up).
Keep the 78 set-up, get a larger cam, add some compression, fly cut your pistons, and run a set of Yella Terra ultralite rockers....that will certainly wake up your combo.
If you need some advise you know where to find me...
Tony
Old Jan 8, 2008 | 10:07 PM
russellnewnham
Thanks for that Tony. I will just leave it as it is.
Old Jan 9, 2008 | 12:32 AM
NemesisC5's Avatar
NemesisC5
Originally Posted by Tony Mamo @ AFR
Russ...
Tony
Solid advice from Tony "The Source" Mamo I just put my brain on pause and ask Tony, works every time
Old Jan 9, 2008 | 01:34 PM
0Tony Mamo @ AFR
Former Vendor
Scotty....your a crack up!
Got a good chuckle out of reading your commentary....
Hope all is well!
Tony
Old Jan 9, 2008 | 02:57 PM
hotwheels57's Avatar
hotwheels57
Isn't FAST introducing a 92mm LSx manifold soon? That should flood the used parts market with 78mm and 90mm manifolds.
Also, I asked in another post and didn't get an answer...when you port a composite manifold, do you use the same burrs, etc that one would use in a metal manifold?
(verano29 is curious, also)
Old Jan 9, 2008 | 06:43 PM
0Tony Mamo @ AFR
Former Vendor
The 92 mm is marketing BS and something to kick some juice back into that line of manifolds. The fact the new ones come with stainless hardware and a deeper properly machined O-ring groove is a nice perk but trust me the 2mm larger opening wont even make a single HP more on the dyno. The opening of that manifold is not the restriction....the restriction is further down the line in the port architecture and design itself. Not to mention most customers will have already choked that airpath somewhere in front of the 92mm opening due to a 78 or even an 85mm MAF.
Regarding the porting tools I use some of the same tools I use for porting aluminum. Its very easy to put a divet in the plastic intake and slow calculating material removal is the order of the day.
Tony
Old Jan 9, 2008 | 07:29 PM
hotwheels57
Thanks Tony!
Old Jan 9, 2008 | 07:37 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
So even though the current FAST 90 manifold can be opened up and port-matched to a 95mm TB...there is no point in doing so?
Old Jan 9, 2008 | 08:32 PM
0Tony Mamo @ AFR
Former Vendor
Correct...and you would run into the O-Ring groove at 95mm....you could port one to 92mm which is essentially what Comp is doing at the factory (pushing the opening very close to the O-Ring groove), but it wont do squat for you in additional power. If a 78 ported FAST intake is only worth 5 less HP than a ported 90 mm FAST, think about what an extra two mm would be worth. Also consider that by the time you get to 90 mm you are seriously into the point of diminishing returns (because of restrictions further up the line and inside the intake itself) it becomes clear the 92 won't do didley....if it did dont you think Comp would have spoken about it.
A 78mm to a 90mm jump increases surface area by 33% (which is very significant but more significant is the fact that assuming the rest if the intake path was optimized, the 78mm TB represented a restriction in the air path and going bigger would then potentially net you some gains).
A 92 mm opening is only a 4% increase (over the 90 set-up)....BUT, other restrictions along the way have already made that a mute point anyway.
Regards,
Tony
To 78 mm fast - mamo ported
