Oil Temp and Pressure Sensors
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
Got an off the wall idea today and want to see if it's feasible. The oil pressure sensor on the APS TT kit is relocated to a flow through block, and a lot of owners have experienced a theoretical loss in pressure as indicated on the gauge, myself included. As I was installing some headers last weekend, I found the oil temp sensor above the oil filter.
Do you guys think the oil temp sensor and oil pressure sensors could be swapped to each others position??? Extending the wires wouldn't be a big deal at all, but what i need to know is if they will physically fit in the opposing position. I'd like to try this to see if this would solve the low pressure indications with the APS turbo kit.
Theoretical may not have been the best word. It was a false pressure loss. The sender in the stock location was the end of a passage, no flow through. The oil distribution block of the APS kit puts the sensor on a flow through location where the oil is being drawn to the turbo's, thus the pressure drop. Moving it to where the temp sending unit it might give a more realistic pressure reading, and i say might because that might be a flow through location too, but it'll probably be a little more realistic than where it is right now.
RIght. A hose runs from there to a distribution block where the twin lines to the turbo's are and the new location of the pressure sensor. Most people were seeing on average a 10 PSI drop on the gauge. I'm just trying to see if the pressure and temp sensors could be swapped for locations to get a better bead on the oil pressure as what I'm seeing right now is a false reading.
I wonder why they did not take oil from the left side of the block?, that's where my SC oil system plugs in. Seems it would make more sense, so you don't have to disturb the OPS, although, it does make it easier to change should it go bad now. I think you would be better off relocating the OPS to the left side of the block. If you change the location of the oil temp sensor, it might not read correctly for the actual temp in the pan.
Awesome. I'll look into that. Those are 1/8 NPT threads on the sender, right?? Just got to make sure I've got a plug for the turbo distribution block. That, and see about wiring harness extension and routing.
I'm not certain on the threads, check the sticky, might be some info in there.
