4 Stock Cats vs. 2
Old Jan 9, 2008 | 10:39 AM
bgray's Avatar
bgray
Default 4 Stock Cats vs. 2
I have an 02 coupe with factory exhaust. I just bought the full exhaust from a ZO6. The TI part was the main reason and the rest is just a perk. My car has the 4 cat setup and the ZO6 has only the 2 cats. Is it worth changing from the 4 cat to 2 cat setup? I plan on a blower soon and that is what prompted the change as the performance for now will probably be nothing. If the pups do cause enough resistance to change, what do I need to do with the front set of sensors? Thanks in advance for your input!
Old Jan 9, 2008 | 11:12 AM
The Wrench's Avatar
The Wrench
Info here suggests the PUPs cost about 5 HP.
Also, the Ti mufflers will sound a bit better without them.
Are the front O2 sensors upstream or downstream of the Pups?
I don't have them, but I think they would be definitely upstream, just below the manifolds.
In that case, no changes required to anything, the computer will easily adjust to the minor flow improvement of the Z06 midpipe and mufflers.
The rear O2's (downstream berind the cats) only serve as a sensor to tell if the cats are changing the O2 content of the exhaust - as long as a reasonably effective cat, either c5 or z06, is in there, these sensors will see a bit of difference from the fronts, and be fine. Removing Pups will not appreciably affect them.
So, do it, no downside at all.
DG
Old Jan 13, 2008 | 03:25 PM
bgray's Avatar
bgray
What's the best idea of what to do with the O2 sensors before the cats? Should I get the new ZO6 2 cat pipe changed to hold them before the cats? Can I just disconnect them without throwing a code?
Old Jan 13, 2008 | 03:40 PM
vincentjames501's Avatar
vincentjames501
Get some aftermarket headers. The TI's will keep them quiet.
Old Jan 13, 2008 | 04:13 PM
XtremeVette's Avatar
XtremeVette
Original Founding Member!
Cruise-In 1, 3, 9. 10 & 11 Veteran
Default ummmmmmmmm
Iam a little confused now....can someone please take a picture of a stock setup 2002 with 4 cats? Am I missing something, I could of sworn mine only has 2. I don't have a Z either. My 2 are right up front near the firewall. Where are the other 2 suppose to be?
Old Jan 13, 2008 | 07:57 PM
Mike Mercury's Avatar
Mike Mercury
http://mikemercury.home.att.net/precats.htm
Old Jan 13, 2008 | 09:20 PM
XtremeVette
Default ok
Originally Posted by Mike Mercury
ok thanks for the picture.....
so what do guys going to headers do? Do we just use the 2 main cats and forget the lil pups?
Old Jan 13, 2008 | 09:52 PM
fdxpilot's Avatar
fdxpilot
Most people going with headers use one of the better systems, like LG, Kooks, or Dynatech, which come as a complete system from cylinder head to the Cat-back connection, with either off-road pipes or hi-flow cats, and an X-pipe. The factory cats end up on the trash heap.
Old Jan 14, 2008 | 07:30 PM
XtremeVette
ok thats what I thought....so we just end up with 2 cats and the lil pups are eliminated. Iam guessing that the 2 main cats that usually are replaced with hi flow ones, do the job and you won't throw any codes.
To 4 Stock Cats vs. 2
