Leaking transmission fluid
Old Jan 9, 2008 | 08:47 PM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
Default Leaking transmission fluid
My mechanic says the gasket between the transmission and rearend is leaking.
Can you tell me what's involved in replacing the gasket, ie, cost, labor and time.
Old Jan 9, 2008 | 09:36 PM
bobc997615's Avatar
bobc997615
I'm not sure it's the "gasket" between the tran & diff. There is no gasket. There is a seal plate which has a o-ring on the perimeter and a output shaft seal. I would be questioning what the heck your mechanic is talking about.
Many threads on this leak, here's one of them...
http://forums.corvetteforum.com/show....php?t=1902902
Old Jan 10, 2008 | 03:24 PM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
Thanks for the reply and the TSB info.
I'm sure my semi-retired GM mechanic knows it's a seal.
It's me you should be questioning.
I'm guilty sometimes of interchanging the two words.
Old Jan 10, 2008 | 03:43 PM
lucky131969's Avatar
lucky131969
I'm confused....You had a mechanic look at your tranmission, he diagnosed the problem, but he cannot give you an estimate for the repair??
To Leaking transmission fluid
