Mark Shaner (S2 Performance) is probably the most well known porter on the forum. Does a great job. Your looking between $150.00 and $200.00.
I don't think there is really any hp gains associated. If there is it is very few. However, the throttle response is AMAZING!. You will notice a difference in the feel and you will love it!
Negatives- None really, once you have it installed. There can be some down time while you wait for your TB to be completed.
I have seen Mark Shaners (S2 Performance) work-
VERY nice.
check the C5 parts for sale I know of someone that will be listing
one soon (shaner ported stock TB).
He is moving up to a 90mm and a fast 90.
I learned a long time ago, much like sheetrock, there are some things that you could do yourself, but you would way better off working a little OT at your day job and hireing done! hahahaha
Mine went on along with a home installed ECS Novi so no way to judge gain but it sure looks fine!
Cost - $150
Who does it - Mark Shaner
Performance gain - Vastly improved throttle respose. (Gets you to the powerband faster) probably picked up some HP to especially at the top end.
Negatives - You'll need to buy a "tamper proof" torx 15 bit to swap out the Throttle body electronics... or have your locak mechanic let you borrow his.
thanks frank. aka Mr. Jones im it. s-2 mark does real nice porting. sent him my 90mm t/b for porting and after 90mm intake is painted and t/b delievered from s-2 and installed i will post for sale the ls-6 intake and 78mm ported t/b for sale
Cost - $150
I found the tamperproof torx bit at Sears. Two autoparts stores I tried didn't carry them.
If your not going to do it yourself, Shaner does an excellent job. I've never read that anyone was dissatified with his work.
Its a good mod! Well worth it!
Dan
After port and polish 10 hp increase
Fast throttle response
Can have slight rpm increase on start up which will subside
Best results with larger bridge/increased air intake(filter)
Cost - $150
just be prepared to be on the phone awhile, he will talk your ear off i found a set of tamper proofs at the auto parts house, not autozone or o'reallys or other chains, a real auto parts house.
