Callaway swaybars
Old Jan 10, 2008 | 06:40 PM
eec8059's Avatar
eec8059
Default Callaway swaybars
Anybody have any info on these? They don't seem to be too popular here in the forums, it seems.
Are they hollow? What are their diameters?
Old Jan 10, 2008 | 06:51 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
link?
Old Jan 10, 2008 | 06:57 PM
eec8059's Avatar
eec8059
Link:
http://www.corvettesofhouston.com/pr...roducts_id=181
The Callaway website has the same info.
Old Jan 10, 2008 | 08:13 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Those look like the T-1 bars I used to have on my car.
Old Jan 10, 2008 | 08:18 PM
John Shiels
May be T-1 from GM with a Callaway decal. Price is OK if it is. Ask them the difference, the size and wall thickness if hollow which I am sure they are.
Old Jan 10, 2008 | 10:20 PM
jeanlucpicard's Avatar
jeanlucpicard
Go with the Pfadt street bars - the Callaway's are not worth the money. My Hotchkis bars are better than the Callaway and I am replacing those next weekend with the Pfadt street bars.
Old Jan 11, 2008 | 12:41 AM
mcv's Avatar
mcv
Callaway bars aren't T1 bars with Callaway decal. They're built to Callaway engineering and quality specs. Standard equipment on Callaway C16, optional on Callaway Corvette. I'll get you diams tomorrow, they are hollow.
Old Jan 11, 2008 | 12:42 AM
mcv's Avatar
mcv
Curious. What makes you say the Callaway bars are not as good as the Hotchkis bars?
Old Jan 11, 2008 | 12:01 PM
eec8059's Avatar
eec8059
Great! Thanks for the specs, will wait for the diams
Old Jan 11, 2008 | 12:04 PM
bowmanized's Avatar
bowmanized
Old Jan 11, 2008 | 12:32 PM
C5B's Avatar
C5B
I'll respond to this, even though I didn't have an opinion beforehand. Looking at them, the bars aren't tunable for over/understeer. The Hotchkis rear bar has three different settings so you can tune to your liking. An adjustable link is not the same as being able to adjust the effective tension of the arms on the bars.
That's one reason that I would prefer the Hotchkis bars.
And, I believe the T1 bars have a similar adjustment to the Hotchkis.... do they not?
- Colby
Old Jan 11, 2008 | 03:05 PM
mcv's Avatar
mcv
- Colby
The Hotchkis products are high quality, fine parts, without a doubt. However, I did not know that "The Hotchkis rear bar has three different settings so you can tune to your liking". They don't show this feature in their catalogs or web site. I don't mean to impose but could you please describe this further or point us to some illustration.
The Callaway stabilizer bars are equipped with adjustable end links with Heim joints to allow preload adjustment. The Hotchkis catalog also lists adjustable end links (ball joint-style) as an option. I don't think GM's T1 bars have any adjustability.
Here's a photo of the Callaway bar kit (suggested retail $630, C5 or C6):
Old Jan 11, 2008 | 03:08 PM
mcv's Avatar
mcv
Bar diameters are: 1.25" front, 1.00" rear.
Old Jan 11, 2008 | 03:16 PM
C5B's Avatar
C5B
Here you go.... follow this link and see the highlighted text:
http://www.hotchkis.net/p-739-c5-cor...y-bar-set.aspx
Excerpt from above link:
Features:
Lightweight, durable 1.25” (1 ¼”) tubular steel front sway bar. 115% stiffer than Z51.
Lightweight, durable 1” adjustable tubular steel rear sway bar. Stiffness increase over Z51 +60%, +100%, +150%.
Factory style oil impregnated rubber bushings included.
Gloss black powder coat finish.
Benefits:
Dramatically improved cornering potential
Improved chassis balance and steering response
Adjustable rear bar allows suspension to be finely tuned
Improves both Z06 and Z51 models
Allows power to be applied earlier during corner exit
The "+60%, +100%, +150%" refers to the three levels of stiffness available above z51.
- Colby
Old Jan 11, 2008 | 03:56 PM
mcv's Avatar
mcv
Features:
Benefits:
- Colby
OH!
Sorry, Colby, I didn't realize that's what you were talking about. I guess I assumed something more elaborate. Oops.
With the Hotchkis bars, there are three holes at each end of the rear stabilizer bar. You can fine-tune the "stiffness" of the bar by selecting the proper hole to locate the end link.
The Callaway bars also have the three-hole mounting feature. Not sure exactly how the Callaway bar stiffness compares to the Z51 bar, though. I'm sure our engineers know, if anyone's interested.
Old Jan 11, 2008 | 04:23 PM
C5B's Avatar
C5B
Ah, ok. The pictures only show one hole on each end of each bar. Must be old photos or something.
- Colby
Old Jan 11, 2008 | 04:42 PM
mcv's Avatar
mcv
- Colby
Right. Older photo.
To Callaway swaybars
Old Jan 11, 2008 | 08:35 PM
eec8059's Avatar
eec8059
Since we're on the topic, this would be useful information.
Old Jan 12, 2008 | 11:35 AM
corvettebob1's Avatar
corvettebob1
Interesting, the Callaway bars look exactly like the Hotchkis bars I have on my 98 coupe including the heim joint end links.
Old Jan 25, 2008 | 08:43 AM
robz's Avatar
robz
What's the lightest bar you could buy and how much does it weigh?
