I have a 98 coupe with a TI catback, other then the catbacks the entire exhaust is stock. If I install an aftermarket X pipe will the exhaust sound be louder and will the idle have more rumble than it does now?
Thanks for everyones help.
My X-Pipe actually made it quieter at certain RPM's and deff will NOT make it rumble more--it gives it a more of an aggressive rasphy sound when on it hard rather than the typical low rumble--
If your looking for a deeper rumble, install a set of long tube headers and bolt them up to the ti's. I like the sound on my '04.
I have a stock 2002 Z06 - installed a Magnaflow X-pipe to rid the H-pipe jingles.
The X-Pipe absolutely quiets down my exhaust - but at least it got rid of the jingles.
I absolutely preferred the exhaust with the original H-Pipe; just could not stand the jingles.
If you have no jingles - keep the oem H-Pipe and have a much better sound.
Originally Posted by SUNNYD 95
I have a 98 coupe with a TI chaatback, other then the catbacks the entire exhaust is stock. If I install an aftermarket X pipe will the exhaust sound be louder and will the idle have more rumble than it does now?
Not so much as louder but have a more agressive sound!
The H-Pipe does not have the efficiency as an X-Pipe does and it will alter the sound of the exhaust but if your looking for louder that is not the way but it will net you some better flow!
