Kooks Headers
Old Jan 12, 2008 | 08:23 AM
johnnied's Avatar
johnnied
Default Kooks Headers
I just recivied my kooks headers and they have , like a flare at the end of the collector, do I need their mid pipe? It dose not look like a normal collector will work? Or can a muffler shop flare the end of the pipe to go inside?
Old Jan 12, 2008 | 01:03 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
you are correct, you will have to have a comparable flare at the end of your midpipe along with a matching header flange to bolt up to. i use grade 8 coated sae bolts 2 1/2" long with washers. they stay tight, have not rusted, and are taken off with no problems. do not use stainless fasteners, i have already gone that route and had to replace them.
Old Jan 12, 2008 | 01:52 PM
ArKay99's Avatar
ArKay99
One question. Is there a floating mounting flange behind the bead on the collector's lip? If so you will need to do as Sleazy Rider said. If not, send them back and get that put on.
To Kooks Headers
