OEM spark # and plug gap confusion
Old Jan 12, 2008 | 05:40 PM
David426's Avatar
David426
Default OEM spark # and plug gap confusion
I've got a 99 with stock plugs 41-931. 56k miles.. Pulled 2 plugs and it looks like the gap is .062 with normal wear.. Owners manual says .060 I've seen other posts claiming a 41-952 as the stock plug with a .040 gap.. Looks like they may have changed plug numbers and gap specefications on the later model LS-1.. .062 sound ok? Car runs fine from idle to red line.. I'm going to the NGK TR55 copper plug as soon as spring rolls around. Just wanted to make sure I get the right plug and gap for my 99.. Or does it matter and whats the difference on the later model plugs and different gaps?? Why did GM change this? I'm sure someone knows
Old Jan 12, 2008 | 05:46 PM
Mike Francoeur's Avatar
Mike Francoeur
They're .060 stock, not .040. I'm not sure what the stock plug number is, we generally use a NGK TR-55 in a stockish car.
Old Jan 12, 2008 | 06:01 PM
BlackZ06's Avatar
BlackZ06
AC Delco came out with an Iridium tip plug in late 2003 .... GM has used that as the factory installed plug since then, and recommends the plug as the replacement for the original platinum tip plugs.
The AC Delco part number is 41-985, and the GM part number is 12571164 ..... the new plug comes pre-gapped (correctly) at 0.040 look here for info on the plug ....
http://www.acdelcotechconnect.com/pd..._03D-J-171.pdf
Old Jan 12, 2008 | 06:45 PM
David426's Avatar
David426
thanks for the info guys.. Much appreciated
To OEM spark # and plug gap confusion
