Clunking Noise in rear end?
Old Jan 13, 2008 | 12:00 PM
jeffrow68's Avatar
jeffrow68
Default Clunking Noise in rear end?
I'm hearing a slight clunking noise in the rearend on my '01, 45K miles, 6 speed. Is this normal, or something I should be looking into further? Jeff
Old Jan 13, 2008 | 12:20 PM
c3andc5's Avatar
c3andc5
If it's a chattering noise at slow speeds, especially in turns then you should look at your rear diff. The limited slip posi-traction may be slipping. When was the last time you serviced your rear diff?
On the other hand, if it is more of a "clunk" noise then I can tell you what to check. The 97-01 have plastic sway bar end links and when those go bad they make a clunking noise. In fact, that just happened to me last month. Replace your end links with the new cast alluminum ones they put on the 02-04. Same ones for front and rear.
Old Jan 13, 2008 | 01:23 PM
jeffrow68's Avatar
jeffrow68
Its not a chatter, its definately a clunking noise. I hear it while shifting in the lower gears, and when accelerating/decelerarting. Now that I hear it, it is becoming more obvious. I will check the mentioned items that you suggested. Thanks, Jeff
Old Jan 13, 2008 | 04:37 PM
whohidjohn's Avatar
whohidjohn
5th Gear
Try the "u joints".
They R the weakest link in a drive line system.
To Clunking Noise in rear end?
