The right rear rear turn signals on My C5 does not work. The front works but flashes like one of the bulbs is burnt out. The rear bulb is good. First the right signal started to work intermittingly then, stopped working all together. The four way flashers work on all corners of the vehicle. The right rear turn signal does not. any Ideas?
Could be a grounding issue, I would check for power using a probe to see if it's getting juice, if it is getting juice then you have ground problem.
If no juice you'll have to trace circuit. Switch is on connection C209 under the knee bolster.
