Help change engine light
Old Jan 14, 2008 | 10:08 PM
03z06BLK's Avatar
03z06BLK
Default Help change engine light
How do you check what codes it is throwing 03 z06 thanks
Old Jan 14, 2008 | 10:09 PM
Today's problem is..'s Avatar
Cruise-In VI Veteran
St. Jude Donor '09
Damn, change engine light? Does it tell you what engine have to install instead or is that up to you?
Old Jan 14, 2008 | 11:14 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Check it out.
http://www.corvettedoctor.com/Code_Main.html
Old Jan 14, 2008 | 11:17 PM
BlackZ06's Avatar
BlackZ06
I think you hopefully mean "CHECK ENGINE" light ... the "CHANGE ENGINE" light only comes on when you run a +14 second time at the dragstrip .....
To look for codes ... follow these instructions .... post the codes and someone will help you in diagnosing the "CHECK ENGINE" light ....
https://www.corvetteforum.com/techti...D=26&TopicID=1
Post the entire code, such as P1234H .... the leading letter tells us what part of the car posted the code (P is Powertrain, B is Body ... etc) and the last character (C, H or CH) tells us if the code is Current, History, or both ....
Old Jan 14, 2008 | 11:31 PM
lucky131969's Avatar
lucky131969
Wow..change engine light . I wish I would get one of those.....then I would have to order my forged block.
Old Jan 15, 2008 | 10:53 AM
03z06BLK's Avatar
03z06BLK
lol i didnt even notice lol i figure it out thank god it didnt say change engine i only have 25k on this one thanks guy
Old Jan 15, 2008 | 06:29 PM
VicCaerter's Avatar
VicCaerter
lmao best one ive heard all day. check codes = press and hold options button + press fuel button 4 times.
Old Jan 15, 2008 | 06:58 PM
BlackZ06's Avatar
BlackZ06
What is so funny .... go try it on your Corvette ... turn ignition to ON (don't start engine) and while holding the OPTIONS button on DIC panel press FUEL four times ....
The Corvette is the only car I know of that will then enter a display mode that cycles through each control module in the car and displays any/all Diagnostic Troube Code's (DTC) stored in the modules.
This feature apparently upset a lot of people in the GM world, it was removed from the C6 Corvette .....
Old Jan 16, 2008 | 03:39 AM
DocPapillon's Avatar
DocPapillon
Originally Posted by ajg1915
Thanks - Great link
To Help change engine light
