code help
Old Jan 14, 2008 | 10:23 PM
03z06BLK's Avatar
03z06BLK
Default code help
10-pcm p0172h
10-pcm p0175h
60-ipc u1255h
a1-rdcm b2283h
a1-rdcm b2285h
u1064
thanks guys only thing i have is a aftermaket stero
Old Jan 14, 2008 | 10:47 PM
03z06BLK's Avatar
03z06BLK
ttt
Old Jan 14, 2008 | 11:03 PM
vincentjames501's Avatar
vincentjames501
http://www.stengel.net/diccodes.htm
I'm looking up your codes now. I'll post them for everybody's reference in a few secs
Old Jan 14, 2008 | 11:07 PM
vincentjames501
Originally Posted by 03z06BLK
10-pcm p0172h Fuel Trim System Rich Bank 1
10-pcm p0175h Fuel Trim System Rich Bank 2
60-ipc u1255h Generic Loss Communications
a1-rdcm b2283h Battery #1 Fault
a1-rdcm b2285h Battery #2 Fault
u1064 Loss of Communications with BCM
Clear all of the codes. The only one of concern is the fact that you pulled a code for running rich. Check your MAF for starters and vacuum leaks (which typically lead to lean conditions but never hurts to check). The other codes are no big deal, just delete them.
Old Jan 14, 2008 | 11:11 PM
03z06BLK's Avatar
03z06BLK
Does the the h behind 10-pcm p0172h does that mean history of it?
Old Jan 14, 2008 | 11:15 PM
vincentjames501
yes, It means you are currently not pulling the code. Delete them and wait to see if they come back... If they do, then you may have a fix on your hands. Then again, rich is not bad. Lean would be a definite thing to fix.
To code help
