Do sparkplugs having anything to do with tempature levels?
Just changed plugs and wires on a 2002 Z06. (stock plugs / wires replaced) Plugs are ACDelco iridium left pre-gapped . I notice my temp runs a little hotter than before. Temps area still in the normal range. While driving the temp remains the same temp as before 190 +-. although, at idle or stop and go traffic, it runs +- 220 - 225 maybe slightly higher, where it didnt before. fans working, nothing blocking air flow etc.. Is there anything I need to consider doing....?
they were one of the plugs listed for the make, model, yr. the plugs are ac-delco iridium 41-985. should i be concerned about these plugs?
Reason: additional info added
Yes, spark plugs can affect engine operating temperature. However, if the plugs you installed have the same heat range as the ones you removed, you should see no difference in engine temperature.
All I can say is O.M.G.This is a perfect example of my statement " Be careful who you listen too"
Internal combustion temperatures are controlled by engine coolant, and heat exchange, fuel mixture, proper tune , fuel trims, and ecm input.
Plug heat ranges are there to tolerate a specific engine design, not the other way around... when you modify and re tune and increase combustion temps, you want to reduce the heat range of the plug.
Bill aka ET
A cold plug conducts heat away from the spark plug tip and cools its temperature. However, a "cold" plug will not measureably affect the overall engine temperature.
But, too hot a plug may lead to a pre-ignition condition, which can noticeably increase engine temperature.
The AC 41-985 plug should be the proper plug and heat range for a 2002 Z06.
Aren't we being overly dramatic and, perhaps, a bit pedantic?
You and people like you are the reason your guessing and now your back peddling has cause many members to cause damage to their car...
first you said that plugs can change engine temps, and now you are back peddling.
OMG means OH my God... I dont know what type of engineer you claim to be but I will tell you that with my 40 years of automotive engineering my last seven in the development of the C5 platform.. I can tell you first hand that many people like you have come and gone from here.... if you want to be a hero here you need to know alittle about the car.
But in this case, this is very basic automotive technology. To which you failed miserably.. and yes an OMG is appropriate
I may be a lot of things but back peddling I'm not; nor am I trying to be a hero.
My second statement: "Too hot a spark plug may lead to a pre-ignition condition, which will cause an increase in engine temperature." seems to be consistent with my earlier statment about spark plugs affecting engine temperature. Doesn't it?
Moreover, an increase in engine temperature due to pre-ignition was basic automotive technology as I understood it some years ago. Now if I'm incorrect, I'm willing to take my licks, but back pedelling I'm not.
You made your back peddling post after I OMG'd you and your post...
FYI, too hot a spark plug will over time melt the porcelain insulator and create what is the equivalent of a glow plug in a diesel, and this is what would cause detonation. Even if you used the hottest plug in the given reach and thread it would not cause detonation immediately, the plug range is designed to protect the plug....
As I mentioned earlier.. tuning ( which includes timing ) engine coolant, heat transfer, fuel trims, and ecm inputs all effect combustion temps.. Octane and engine temps effect detonation. I made no mention of plugs, anywhere in the combustion temperature equation.
Bringing up pre-ignition Now is just back peddling... this is three more post than I wanted to place in this thread... Bottom line here is
a 'hotter' plug won't/can't raise engine temps. at worst, you could get some pinging, which in turn will cause the ecm to pull timing and slow down the car.
run hot? no. and 30 degress hotter....impossible
While you said you had checked, I just want to be sure you looked carefully under the front of the vehicle into the "plenum" where air from the road is drawn up and through the A/C condenser and radiator. These cars are "bottom breathers" and love to suck paper/plastic bags, leaves, and other trash off the road and into the A/C condenser, which then blocks cooling air to the radiator. A paper bag from MickeyD's will substantailly raise your coolant temperatures .....
