Wow!! Holy Codes Batman!
10-PCM - Powertrain Control Module
P1571 ASR Desired Torque
P1644 Delivered Torque Output Circuit
28-TCS - Traction Control System
C1221 LF Wheel Speed Sensor Input Signal is 0
C1222 RF Wheel Speed Sensor Input Signal is 0
C1226 LF Excessive Wheel Speed Variation
C1281 Steering Sensor Uncorrelated Malfunction
60-IPC - Instrument Panel Cluster
B1537 DIC Switch 6 Signal Short to GND "RESET"
B0521 Tachometer Signal Circuit Malfunction
U1040 Loss of Communications with TCS
80-Radio
U1016 Loss of Communications with PCM
A0-LDCM - Left Door Control Module
B2236 Left Door Lock Switch Fault
B2238 Left Door UnLock Switch Fault
B2282 Battery #1 Fault
B2284 Battery #2 Fault
B2262 Horizontal Position Sensor Fit
U1255 Serial Data Line Malfunction
U1064 Loss of Communications with BCM
U1096 Loss of Communications with IPC
A1-RDCM - Right Door Control Module
B2283 Battery #1 Fault
B2285 Battery #2 Fault
A6-SCM - Seat Control Module
B2172 Seat Front Up Switch Shorted to GND
B0851 Battery 1 Out of Range
I'm sure you could open any C5 that hasn't had codes looked at or reset in a while and pull up a long list of history faults
Ya, don't worry. The battery going out could do that kind of stuff. If you want some piece of mind, clean up the two ground points in the engine compartment and put some dielectric grease on them. It will save you some headaches latter on, and very easy to do. Look in the electrical sticky for location and photos.
And Welcome to the forum!
80-Radio
Any thoughts?
80-Radio
Any thoughts?
Here is the diagnostic info for C1281. The lower portion is a trouble shooting table which doesn't translate well when pasted into the forum so the format may look a little strange.
DTC C1281 Steering Sensor Uncorrelated Malfunction
Circuit Description
The EBTCM uses four inputs from the Steering Wheel Position sensor:
Phase A digital input
Phase B digital input
Index pulse
Analog input
This information is used to calculate three things:
The front wheels position when centered.
The front wheels position when turning.
The rate at which the steering wheel is turning.
The EBTCM runs a centering routine when the vehicle speed goes above 30 Km/h (18 mph). When the vehicle reaches 30 Km/h (18 mph), the EBTCM monitors the Steering Wheel Position Sensor inputs (Phase A, Phase B and Analog voltage) to see if the steering wheel is moving. If the steering wheel is not moving for a set period of time then the EBTCM assumes the vehicle is going in a straight line. At this point, the EBTCM looks at the analog voltage signal and reads the voltage. This voltage normally around 2.5V, is then considered the center position and the digital degrees also become zero at the same time. This centering routine is necessary to compensate for wear in the steering and suspension. Wear in the steering and suspension can result in a change in the relationship between the steering wheel and the front tires when driving in a straight line. By running the centering routine the EBTCM can compensate for these changes by changing the digital and analog center position.
The EBTCM uses the digital input (Phase A and Phase B) from the Steering Wheel Position Sensor to calculate the direction the driver of the vehicle is trying to steer during an ABS event. This information is also used to calculate the rate at which the steering wheel is turning to control the amount of effort required from the driver to turn the steering wheel using Magna Steer®.
Conditions for Setting the DTC
DTC C1281 will set when the digitally derived centered angle differs from the analog derived angle by 27° or more for a period of 5 seconds.
DTC C1281 will set if the index pulse is not seen between ± 37° or is seen between -185° and -37° or 37° and 185° of steering wheel travel.
DTC C1281 will set if phase A and or phase B are shorted.
Action Taken When the DTC Sets
Magna Steer® is disabled, ABS/TCS remains active.
Conditions for Clearing the DTC
Condition for DTC is no longer present and scan tool clear DTC function is used.
Fifty ignition cycles have passed with no DTC(s) detected.
Diagnostic Aids
If the analog Steering Wheel Position Sensor input is missing then DTC C1288 will set.
If the Steering Wheel Position Sensor 5 volt supply or the Steering Wheel Position ground is missing DTC C1288 will set.
It is very important that a thorough inspection of the wiring and connectors be performed. Failure to carefully and fully inspect wiring and connectors may result in misdiagnosis, causing part replacement with reappearance of the malfunction.
An intermittent malfunction can be caused by poor connections, broken insulation, or a wire that is broken inside the insulation.
If an intermittent malfunction exists refer to General Electrical Diagnosis Procedures in Wiring Systems.
Test Description
The numbers below refer to step numbers on the diagnostic table.
Step 3. Checks for the analog voltage to change, if the analog voltage does not change DTC C1281 will set.
Step 4. Checks if the digital Phase A and Phase B are changing state from high to low.
Step 5. checks to see if the analog and digital readings are ± 27° of each other.
Step 31. Checks to see if the EBTCM is supplying the pull up voltage for Phase A.
Step 32. Checks to see if the EBTCM is supplying the pull up voltage for Phase B.
Step 33. Checks to see if the EBTCM is supplying the pull up voltage for the Index pulse.
DTC C1281 Steering Sensor Uncorrolated Malfunction Step
Action (Step # and description)
Value(s) (Measurements, etc)
Yes
No
Step 1
Was the Diagnostic System Check performed?
Go to Step 2
Go to Diagnostic System Check
Step 2
Turn the ignition switch to the ON position, engine OFF.
Using a scan tool read ABS/TCS DTC(s).
Are any of the following DTC(s) present, C1286 or C1288?
Go to Applicable DTC table
Go to Step 3
Step 3
Cycle the ignition switch from the OFF to ON position.
Using a scan tool in the Data List monitor the Analog Steer Sensor Voltage as you rotate the steering wheel from left to right.
Does the Analog Steer Sensor Voltage change as the steering wheel is rotated?
Go to Step 4
Go to Step 6
Step 4
Using a scan tool in the Data List monitor the Digital HWPS Input as you rotate the steering wheel from left to right
Does the Digital HWPS Input change as the steering wheel is rotated?
Go to Step 5
Go to Step 10
Step 5
Using a scan tool in the Data List monitor the Analog Steer Sensor Voltage and the Digital HWPS Input.
Rotate the steering wheel until the Digital HWPS Input reads 50°.
Does the Analog Steer Sensor Voltage read within the range specified in the value(s) column?
2.7 - 3.3V
Go to Step 7
Go to Step 8
Step 6
Turn the Ignition switch to the OFF position.
Disconnect the EBTCM.
Install the J 39700 Universal Pinout Box using the J 39700-25 cable adapter between the EBTCM harness connector and the EBTCM.
Using J 39200 DMM, measure the voltage at terminal 23 of J 39700 as an assistant rotates the steering wheel.
Does the voltage change as the steering wheel is rotated?
Go to Step 9
Go to Step 8
Step 7
Rotate the steering wheel in either direction while monitoring the Digital HWPS Index Pulse with a scan in Data List.
Does the Digital HWPS Index Pulse go HIGH within ± 37° of steering center while rotating the steering wheel?
Go to Step 9
Go to Step 12
Step 8
Replace the Steering Wheel Position Sensor. Refer to Steering Wheel Position Sensor Replacement in Steering Wheel and Column.
Is the replacement complete?
Step 9
Replace the EBTCM. Refer to EBTCM .
Step 10
Using J 39200 DMM, measure the voltage at terminal 20 of J 39700 as an assistant rotates the steering wheel.
Does the voltage toggle between 0 and Battery volts as the steering wheel is rotated?
Go to Step 11
Go to Step 19
Step 11
Using J 39200 DMM, measure the voltage at terminal 4 of J 39700 as an assistant rotates the steering wheel.
Go to Step 9
Go to Step 25
Step 12
Using J 39200 DMM, measure the voltage at terminal 19 of J 39700 as an assistant rotates the steering wheel from the center position to the right.
Does the voltage toggle between 0 and Battery volts one time as the steering wheel is rotated to the right?
Go to Step 9
Go to Step 13
Step 13
Turn the ignition switch to the OFF position.
Disconnect the J 39700-25 cable adapter from the EBTCM leaving the J 39700-25 cable adapter connected to the EBTCM harness connector.
Disconnect the Steering Wheel Position Sensor connector.
Using J 39200 DMM, measure the resistance between terminals 19 and B of J 39700 .
Is the resistance within the range specified within the value(s) column?
OL (infinite)
Go to Step 15
Go to Step 14
Step 14
Repair short to ground in CKT 1765. Refer to Wiring Repairs in Wiring Systems.
Is the repair complete?
Step 15
Using J 39200 DMM, measure the voltage at terminal 19 of J 39700 .
Is the voltage within the range specified in the value(s) column?
Above 1V
Go to Step 16
Go to Step 17
Step 16
Repair short to voltage in CKT 1765. Refer to Wiring Repairs in Wiring Systems.
Step 17
Connect a jumper wire between terminals 19 and B of J 39700 .
Using J 39200 DMM, measure the resistance between the Steering Wheel Position Sensor harness connector terminal 5 and a good ground.
Is the resistance within the range specified in the value(s) column?
0 - 5ohms
Go to Step 33
Go to Step 18
Step 18
Repair open or high resistance in CKT 1765. Refer to Wiring Repairs in Wiring Systems.
Step 19
Using J 39200 DMM, measure the resistance between terminals 20 and B of J 39700 .
OL (infinite)
Go to Step 21
Go to Step 20
Step 20
Repair short to ground in CKT 1763. Refer to Wiring Repairs in Wiring Systems.
Step 21
Turn the ignition switch to the On position, engine OFF.
Using J 39200 DMM, measure the voltage at terminal 20 of J 39700 .
Above 1V
Go to Step 22
Go to Step 23
Step 22
Repair short to voltage in CKT 1763. Refer to Wiring Repairs in Wiring Systems
Step 23
Connect a jumper wire between terminals 20 and B of J 39700 .
Using J 39200 DMM, measure the resistance between the Steering Wheel Position Sensor harness connector terminal 3 and a good ground.
0 - 5ohms
Go to Step 31
Go to Step 24
Step 24
Repair open or high resistance in CKT 1763. Refer to Wiring Repairs in Wiring Systems.
Step 25
Using J 39200 DMM, measure the resistance between terminals 4 and B of J 39700 .
OL (infinite)
Go to Step 27
Go to Step 26
Step 26
Repair short to ground in CKT 1764. Refer to Wiring Repairs in Wiring Systems.
Step 27
Using J 39200 DMM, measure the voltage at terminal 4 of J 39700 .
Above 1V
Go to Step 28
Go to Step 29
Step 28
Repair short to voltage in CKT 1764. Refer to Wiring Repairs in Wiring Systems.
Step 29
Connect a jumper wire between terminals 4 and B of J 39700 .
Using J 39200 DMM, measure the resistance between the Steering Wheel Position Sensor harness connector terminal 4 and a good ground.
0 - 5ohms
Go to Step 32
Go to Step 30
Step 30
Repair open or high resistance in CKT 1764. Refer to Wiring Repairs in Wiring Systems.
Step 31
Reconnect the J 39700-25 cable adapter to the EBTCM leaving the J 39700-25 cable adapter connected to the EBTCM harness connector.
Battery volts
Go to Step 8
Go to Step 9
Step 32
Battery volts
Go to Step 8
Go to Step 9
Step 33
Battery volts
Go to Step 8
Go to Step 9
Hope this is enough to get you started.
Bill
It seems like you have a handle on this type of problem. Most of that list looks like Greek to me. Knowing what you know of the system, could this still be caused by a bad ground? I don't want to spend a whole day cleaning grounds if that is not a possible cause / solution.
