trunk light switch
Old Jan 20, 2008 | 03:17 PM
emj's Avatar
emj
Default trunk light switch
I found the actuating lever to switch the trunk lights on/off. Is the switch replacable, or does the entire latch get replaced? (2000 conv't)
emj
Old Jan 20, 2008 | 04:59 PM
LoneStarFRC's Avatar
LoneStarFRC
Try #16608046. It's the "rear compartment lid ajar indicator switch". This is the switch that lets the BCM know the trunk lid is ajar (unlatched) in order for the BCM to turn on the trunk lights.
There is no separate trunk light switch as such.
HTH
Old May 29, 2012 | 07:50 PM
mret430's Avatar
mret430
Navigator
Where did you find the switch? i am trying to replace mine but have no clue where it's located.
thanks!
Old Nov 27, 2013 | 09:51 AM
toblue02's Avatar
toblue02
Default trunk lights
HTH
were is this switch located,2011 gs vert, no trunk lights??
Old Nov 27, 2013 | 12:09 PM
dadaroo's Avatar
dadaroo
The switch is part of the actual trunk latch. It controls the 2 trunk lights (left and right) and will also activate the interior lights. I think you have to replace the whole mechanism since the switch is integral. Make sure you don't just have a light(s) issue versus the switch. Could be the BCM but if you want to test the actual switch for continuity I can post the pin out for the switch if you need it. The last person I helped on this just had a bad switch. Mr. Sam
Old Nov 27, 2013 | 08:09 PM
LoneStarFRC
This is the C5 section not C6, but the switch is probably part of the trunk lid release solenoid assembly, much like the C5s.
I would think you need to be sure you're looking at the C6 convertible section for it, as the coupes and hardtop (Z06) may be different, i.e. verts have only one latch assembly and coupes have two.
To trunk light switch
