Heater not blowing through vents
Old Jan 22, 2008 | 09:40 AM
Mac78and2K's Avatar
Mac78and2K
Default Heater not blowing through vents
On by 2000 when I have the heat on (automatic control) I can hear the fan trying to blow but little air comes out of the lower vents. Is this a controll issue and how hard to replace it if it is?
Thanks for any help.
Old Jan 22, 2008 | 10:18 AM
SUNNYD 95's Avatar
SUNNYD 95
Your problem may not be a control problem it most likley is a vacumn leak, One of the lines might be split or off of the vacumn source, so you have to trace the lines and find the problem. Don't just through parts at it without diagnosing it first. Good luck.
Old Jan 22, 2008 | 10:44 AM
jellyjam's Avatar
jellyjam
Have have that problem with my 2004, and found it to be a change in the Mode setting. It seems to change to a different mode at times maybe every other week. Change it to what I want and it goes to that selection right away.
Old Jan 22, 2008 | 11:11 AM
aande47's Avatar
aande47
Yes , Try changing the Mode setting
To Heater not blowing through vents
