Traction Needed
Old Jan 25, 2008 | 08:55 AM
Bop Bop's Avatar
Bop Bop
Originally Posted by 9secondflat
or you could do what i did 17 years ago. i had the 5.0 mustang vortech running 10.80@ 125... on the street no traction it would just spin at will. i ran mccreary, m&h, hoosier quick times..nothing helped..
than ding ding one night i had an idea
i drilled two holes above the wheel wells on each side and ran 3/8 inch line into each whole on both sides. the lines-hoses ran into a 1 gallon vht/trackbite can with a pump. ran one line to ground the other to the fuse box and with a switch mounted in my ashtray...i had traction in 5 seconds. someone wanted to screw around...throw the switch, quick burn out and i was running hot sticky tires coated with vht/trackbite...no spinning, dead hooking....and alot of money made with unsuspecting suckers.
Sweet Idea.
Old Jan 25, 2008 | 09:08 AM
9secondflat's Avatar
9secondflat
glad to help
Old Jan 25, 2008 | 10:09 AM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
Originally Posted by Bop Bop
Is there anything I can add to give my car more traction. I'm spinning from 1st to 2nd even with the traction control on. Maybe traction bars?
Traction bars are for preventing wrap-up under heavy accelleration on lengthwise mounted leaf springs. Modern Corvettes use a single transverse mounted leaf in the rear.
I think the answer is better tires and learning to modulate the throttle. It works for me with my 402 stroker.
Old Jan 25, 2008 | 05:04 PM
q8_c5's Avatar
q8_c5
Sounds like it's time for new tires....
BFG Drag radial
