Changing the gears
Old Jan 23, 2008 | 09:39 PM
theslo1's Avatar
theslo1
Default Changing the gears
I used to have a na mustang cobra that i did a gear change in it and it seemed to help it a lot and make it a lot faster. I have a 01 Zo6 and was thinking about changing the gears to make them more aggressive has anybody done this? Do they even make gears for an 01 ZO6? Any opinions welcome?
Old Jan 23, 2008 | 09:54 PM
noahdr's Avatar
noahdr
Are you talking about tranny gears or diff gears? You shouldn't have any problem finding diff gears, I'm not sure about tranny gears for a zo6 though.
Old Jan 23, 2008 | 10:18 PM
motogib1's Avatar
motogib1
Absolutely you can get get gears for Z06. 3.73, 3.90 4.10's. That is why there are used Z06 3.42 rear differentials available.
Old Jan 23, 2008 | 10:29 PM
LTCHAPPA's Avatar
LTCHAPPA
Yes they do,go for the 390s or 410s, about $1500. to have it done
Old Jan 23, 2008 | 10:48 PM
jmzvet's Avatar
jmzvet
Most C5/6 owners change out the entire rear differential aka "pumpkin". It takes skill and special tools to switch out the ring & pinion in a C5/6 diff. It's a simple, although time consuming, task to R&R the rear diff. It's well worth the effort .
Old Jan 23, 2008 | 11:07 PM
Rickyh93's Avatar
Rickyh93
I will be replacing my gears hopefully before spring. The old fashioned way DIY. I figure instead of paying someone to do it I can buy the tools and help other locals do the same and save some money. It will cost me the same either way.
Old Jan 24, 2008 | 09:27 PM
theslo1's Avatar
theslo1
thanks for the info has any of you guys put 4.10s in your cars?
Old Jan 24, 2008 | 09:32 PM
black98c5's Avatar
black98c5
A lot of Z06 guys are very happy with 4.10's.
Old Jan 25, 2008 | 06:53 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
ECS Charges $1395
Old Jan 25, 2008 | 08:49 AM
Mike Mercury's Avatar
Mike Mercury
Automatic or manual tranny?
Old Jan 25, 2008 | 10:52 AM
lucky131969's Avatar
lucky131969
I do all my own work as well. Unfortunately, gear sets occasionally whine, which means if you do it yourself, you either tear it down again or live with it. RPM now dyno's their diff rebuilds. So they are already broken in and checked out when you get it. All you gotta do is install it. That's worth the extra $$ to me.
Old Jan 25, 2008 | 11:00 AM
Johnny Hardcore's Avatar
Johnny Hardcore
RPM? Supporting vendor? Would you happen to have prices?
Old Jan 25, 2008 | 11:18 AM
nj02vette's Avatar
nj02vette
From: Marlton. Increasing performance one speeding ticket at a time! NJ
The Z06 uses the MN12 tranny rather than the MN6 used in coupes. The difference is in the tranny gear ratios. Keep that in mind when deciding on a gear.
4.10's in a MN12 equates to a first gear equivalent of 4.56's for MN6 cars. If you plan to drag the car, going that high may lower your 1/4 due to an extra shift. Just something to think about.
Old Jan 25, 2008 | 11:26 AM
lucky131969
Yes they are. Not knowing what you want to do exactly, or what your needs are, so you are better off calling RPM to get a quote.
To Changing the gears
