Haven't had my 00 C5 out since early December, but with the roads clear I decided to move it to a heated garage to install cat back. Temp was around 0 when I started-DIC displayed active handling warming up. DIC stayed the same for the 20 minutes or so that I drove. Is this anything to be concerned about? Also my RF DDL and turn signal didn't work.
"Active Handling Warming Up" when the EBCM is trying to calibrate the Steering Wheel Position Sensor (SWPS) after engine start. The EBCM needs the car on a flat surface, steering straight ahead (it can tell from the yaw and lateral accelerometers that the car is moving in a straight line) and the car speed must be over 6 MPH, and all of this has to occur for 10 seconds. The EBCM will display the "warming up" message (and turn on the A/H and T/C warning lamps) to warn you that it has not completed its initialization sequence, and until it does, A/H and T/C are disabled. When the EBCM completes its initialization, the DIC will display WARM UP COMPLETE and the A/H and T/C warning lamps will go out as those systems are now active.
If the "Warming Up" message is starting to appear regularly on your Corvette, especially if you've already been driving for a while, that is a symptom that your SWPS may be starting to fail.
Ok this happened to me, the warming up message came on several times but then went off. but now my AH and ABS are both off and wont come back on, im also getting service ABS and AH warnings on my DIC. So could this mean that the SWPS has failed?
Best way to find out is to dump the DTC data from the car's computers to the DIC display. If you don't know how to do this, go here for the instructions ....
It is easiest to write down the codes in MANUAL mode, as they scroll by pretty quickly in the initial scan mode. Post ALL the codes in a new thread, and someone will look them up in the Service Manual and help you diagnose the problem. Be certain to post the ENTIRE code .... it will look something like P1234C or C9898H .... the first letter indicates the code type (Powertrain, Chassis, etc.) followed by 4 digits and then an H or a C (sometimes both) indicating if the code is a History code (problem occured but is no longer occuring) or Current (problem is happening now). .
You can simply delete any Uxxxx codes, they are common and occur because the data bus sometimes is so busy that a computer can't talk with another computer at the moment it wants to.
A faulty Intake Air Temp sensor can be related to this since the EBCM uses that sensor to determine ambient air temp as part of the calibration routine. IAT is on the intake and it's common for its wiring to fray resulting in erroneous sensor readings. As noted, check the DIC codes - if any of the codes are related to IAT reading then I'd check that connector carefully.
Thanks-as usual I learn a lot from forum members. While my catback was being installed she warmed up in a heated garage overnight. Drove it next day and all was fine. Interesting about the IAT. Thanks again!
In what year did the EBCM start using the IAT ?? My 2001 Service Manual shows no wiring for IAT input, and the data listed under the Scan Tool data list does not show temperature data (other than calculated rotor temperatures).
Thanks,
In 2001 the IAT sensor was incorporated into the MAF..
