Supporting mods needed with aftermarket cam?
Jan 25, 2008 | 07:25 PM
On a basically stock 01 Z06 if I want to go with an MS3 or MS4 camshaft what else do I need aside from good valvesprings and a tune?
Jan 25, 2008 | 08:31 PM
You might need different length pushrods depending on the base circle of the new cam
Jan 25, 2008 | 11:18 PM
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
Quote:
Originally Posted by
LDB C5
and even if you could use the same length, I would get stronger ones than stock , nice insurance and piece of mind.
Jan 25, 2008 | 11:20 PM
How much am I looking at for cam/springs/push rods? Also, what's the going rate for labor to install all that stuff?
Jan 26, 2008 | 12:07 AM
Jan 26, 2008 | 08:44 AM
How about a larger than stock wallet??
Jan 26, 2008 | 09:07 AM
It'll have longtubes, why?
Jan 26, 2008 | 11:19 AM
Think about replacing the timing chain with a better one, as well as adding a timing chain tensioner. Maybe the LS2? Do a search. I went with an SLP double roller, but I hear that might not be the best choice (no trouble for me yet). Also, since you're in there, replace the pulley bolt with an ARP. It's only around $25.
- Colby
Jan 26, 2008 | 12:30 PM
St. Jude Donor '08
FrankTank
^^I was advised not to do this because it is better for the pushrod to break than to put the valves into the pistons.
Jan 26, 2008 | 12:33 PM
St. Jude Donor '08
VIPERBLUELX
^^New timing chain, ported oil pump, new pulley, better lifters (LS7), and also consider after-market rocker arms to reduce wear on valve train.
Jan 26, 2008 | 07:06 PM
headers aren't necessary but im pretty sure they're important if you want to see the full potential of any aftermarket cam
