I need to remove teh ASP underdrive pulley to address a bad front main seal. What size are the threads on it ?? I have the correct puller, but I need the 3 bolts.
I tried the web sites. They offer a removal "kit" but all I need is the thread size; I have everything else. I was hoping to get this disassembled tomorrow; but I cant reach anyone at ASP before monday morning.
I have a puller with two different sizes for the 3 bolt pattern. You are welcome to borrow to check the size if you like.
IIRC there are 2 threads for that size bolt. One is coarse, the other, fine. You will need the fine thread, but I can't remember the pitch.
I would send you mine, but I remember I went to a local bolt supplier with the coarse bolts and they sold me the right size bolts with the fine pitch. Cost ~ $4.
