Trans cooler
Old Jan 26, 2008 | 10:38 AM
brit2001's Avatar
brit2001
Default Trans cooler
I am putting in a yank 3200 converter and 3.42 gears. It looks like I will need an trans cooler. I have seen them for sale for about $60. How do you install them and what other parts do you have to buy ( hose, fittings ect...) Where can I get these parts or do they come with the cooler? Thanks
Old Jan 26, 2008 | 02:34 PM
navy99vert's Avatar
navy99vert
Cruise-In VIII Veteran
I used an B&M cooler. I use the hoses and hardware that came with it. You need to use the return line from the rad. (it is the top line)
Old Jan 26, 2008 | 03:23 PM
OhioC5's Avatar
OhioC5
Im doing the same thing in spring, someone need to post up a part number of the best one to use. I see that B&M sells different sizes, it would be nice to know which one fits best. I installed on on my T/A and it was tight to say the least.
Old Jan 26, 2008 | 04:08 PM
brit2001's Avatar
brit2001
Navy99vert Where did you mount your cooler?
Old Jan 26, 2008 | 07:30 PM
tiojames's Avatar
tiojames
Summit sells B&M's 24,000 for a good price and it has about twice the parts you will need for the install. I have it on my tranny with a Yank 3500 and other mods(see sig) and have never had an over heating problem.
Old Jan 26, 2008 | 07:41 PM
OhioC5's Avatar
OhioC5
That seems to be the bigger cooler, any fitment trouble?
Old Jan 26, 2008 | 08:14 PM
_Will_'s Avatar
_Will_
From: Somewhere between mild insanity and complete psychosis
DO NOT use th hose that comes with them, get ss lines.
Fine on my car until I upgraded to a built tranny and aftermarket converter, then the rubber hoses started blowing out. Eventually all had to be replaced with ss, I know all to well the color/consistency/smell of ATF fluid and logged quite a few AAA tow miles.
Do it right the first time.
Old Jan 26, 2008 | 09:57 PM
One Nut's Avatar
One Nut
Are there part#'s for those ss hoses "spacific made" Are yours hard plumed or are they ss flexable hose and a barbed fitting using a hose clamp?
Do you have pics of the install hoses cooler location???
Old Jan 26, 2008 | 11:31 PM
jon c's Avatar
jon c
Old Jan 27, 2008 | 11:25 AM
99 vett babycar's Avatar
99 vett babycar
24K BTU
Old Jan 27, 2008 | 09:37 PM
MattB's Avatar
MattB
Originally Posted by 99 vett babycar
24K BTU
Hate to tell you, but no such b&m cooler. Your thinking of the 24,000 GVW, NOT the best cooler to get.
Look at this one, its a tight fit in front of the AC condenser, but twice the cooling of the 24,000 GVW one...
http://www.jegs.com/webapp/wcs/store...0002_147268_-1
Old Jan 28, 2008 | 01:52 PM
Cary's Avatar
Cary
My B&M SuperCooler is mounted in front of the AC Condenser.
Old Jan 28, 2008 | 02:08 PM
brit2001's Avatar
brit2001
Thanks MATTB for the link. That looks like the one I'll order. Laurence
To Trans cooler
