Removing scuff marks on sill??
Old Nov 30, 2001 | 10:02 PM
TOPGUN9's Avatar
TOPGUN9
Default Removing scuff marks on sill??
Any ideas on how to remove scuff marks on the sills of a C5 other than installing sill protectors??
Old Nov 30, 2001 | 10:10 PM
dexter's Avatar
dexter
Default Re: Removing scuff marks on sill?? (TOPGUN9)
pssst - you're missing the beginning bracket on the [img] in your sig. :D
Old Nov 30, 2001 | 10:20 PM
99HT's Avatar
99HT
If the scuff has not destroyed the clear coat, you can use a wax with a mild abrasive in it or some polishing compound.
Old Nov 30, 2001 | 11:31 PM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
if you are talking about the plastic trim part not the painted sill, lacquer thinner on a rag will remove the shoe scuffs. :chevy
Old Dec 1, 2001 | 01:26 AM
Schwa72's Avatar
Schwa72
Default Re: Removing scuff marks on sill?? (clem zahrobsky)
I use WD40 to remove scuffs on the plastic parts of the sill. It works pretty well, and believe it or not, the back of the WD40 can even suggests using it for scuff removal!
[Modified by Schwa72, 5:27 AM 12/1/2001]
To Removing scuff marks on sill??
