i`m getting a high oil pressure reading on my c-5 . i checked the oil and everything seems to be running great.i even did another oil change.a friend said it might be a sensor going out.any ideas?
Sounds like the Oil Pressure Sensor. Shut the engine off and turn key on. If it shows oil press w/eng off, its the sensor. Located at rear of eng, behind intake maniforld. Search this forum for write ups and pics. HTH
I first bought my car that was something i told the dealership to fix, they changed the sensor, and it turned up being the instrument cluster shorted out. Good luck on removing the intake. I gotta do a knock sensor on my c5. to you and me...
THANKS for the input guys! i did shut the engine off and turned the key on and it showed pressure so it must be the sensor.thanks! now just gotta figure out what i want to do.haha
