Dreaded #7
Old Jan 28, 2008 | 12:15 PM
lucky131969's Avatar
lucky131969
Default Dreaded #7
going no where**************deleted
Old Jan 28, 2008 | 01:03 PM
VetteDrmr's Avatar
VetteDrmr
Interesting they way you asked the question. What mods have you done to your engine?
Want to help, but don't want to go down the wrong path.
Mike
Old Jan 28, 2008 | 01:16 PM
lucky131969
Mike
Well, this isn't about me, it's about those who have lost #7 cylinder, specifically with an LS1, and not running an LS6 or aftermarket intake. I am particularly interested because the LS6/aftermarket intake requires you to block of the air bleed pipe to the rear of the heads.
Old Jan 28, 2008 | 02:03 PM
VetteDrmr's Avatar
VetteDrmr
Ah, Now I understand. Personally, no, I don't know of anyone that's lost the #7 (or #8, which I bet would be similar) due to aftermarket intakes.
That being said, I've read at least one vendor that's had problems with the rear cylinders overheating due to steam pockets. Can't remember which one it was, and I don't want to drag the wrong person into the conversation.
Have a good one,
Mike
Old Jan 28, 2008 | 02:19 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Don't get me wrong, I'm not trying to start anything but this thread is kind of vague and I'm trying to understand.
Does this have something to do specifically with the coolant crossover tube that is only on the LS-1 engine with the LS-1 intake manifold? because plenty of LS-1 engines came from GM with LS6 manifolds and I know I have seen threads about people losing the #7 cylinder with stock engines.
Old Jan 28, 2008 | 02:28 PM
MattB's Avatar
MattB
Do a search in the road race forum, might find some opinions there. Not sure how much, if at all, it contributes.
Old Jan 28, 2008 | 02:29 PM
lucky131969
Yes, it's called the air bleed pipe.
Old Jan 28, 2008 | 07:12 PM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
Changing to an LS6 intake does not require you to change the air bleed pipe. You can leave them as they are and grind down the plastic "grid" on the bottom of the intake where the coolant lines run. I've had mine this way for ~5000 miles.
Old Jan 28, 2008 | 07:29 PM
lucky131969
I give up...Mods please close this thread.
Old Jan 28, 2008 | 08:01 PM
ZeeOSix's Avatar
ZeeOSix
http://forums.corvetteforum.com/show....php?t=1922723
To Dreaded #7
