Window Tip in Adjustment
Old Jan 28, 2008 | 03:29 PM
BugsyK's Avatar
BugsyK
Default Window Tip in Adjustment
Found these instructions but can someone tell me what the "Jack Screw" is?
From the manual:
Window Tip-In Adjustment - Door
Tools Required
#6 Inverted TORX Socket
Position the window fully up.
Remove the large access plug from under the front of the door.
Loosen the window regulator front channel mounting nut.
Remove the reflector from the trim panel
Loosen the jack screw jam nut.
Adjust tip in with the jack screw.
Turn the jack screw clockwise to tip the window outward.
Turn the jack screw counterclockwise to tip the window inward.
One turn of the screw equals approximately 0.04 in change at the top of the window.
Tighten the jack screw jam nut.
Lower the window.
Tighten the window regulator channel front mounting nut.
Raise the window and check the alignment.
Install the access plug under the front of the door.
Install the reflector in the door trim panel. check to insure that the weatherstripping on the top is seated correctly on the targa bar.
Also found this link
http://www.theredlion.us/TipIn.htm
Old Jan 28, 2008 | 04:27 PM
BugsyK's Avatar
BugsyK
Never mind. I got it!
Old May 1, 2023 | 02:34 PM
Bulldogg888's Avatar
Bulldogg888
1st Gear
From the manual:
Tools Required
Lower the window.
Pls send .doc with pics to me, I have same problem with my 50th Anniversary Vette! Thx
Bulldogg888
To Window Tip in Adjustment
