Door lock problem passenger
Old Jan 28, 2008 | 04:15 PM
phillyroket's Avatar
phillyroket
Cruising
Default Door lock problem passenger
Ok...talked about this before...and I have done some investigation with some new facts...
* door does not lock with remote
* door does not lock from drivers side
* door does lock at passanger door lock swith (button)
So where does anyone think the problem lies. The drivers door switch has been replace when I have had window problems...but problem was in connector under dash..
Rocket
Old Jan 28, 2008 | 05:51 PM
TUF-NUF's Avatar
TUF-NUF
From: kent ct - "if i'm not in the vette, i damn well better be on the yacht."
St. Jude Donor '13
Hey, Rocket; My experience with these types of problems usually comes down to the harness that runs through the bellows between the jamb and the door. Look for an exposed wire in there first. It's an easy fix and I'd eliminate that first. Dave ( Check out Bill Curlee's sticky for electrical problems. lots if good info there.)
Old Jan 28, 2008 | 08:45 PM
Bob CTS's Avatar
Bob CTS
Check the door bellow as mentioned above, when mine did this it was the relays in the door control module. Here is a good link:
http://forums.corvetteforum.com/showthread.php?t=1606865
Old Jan 28, 2008 | 08:48 PM
Ilovechevymusclecars's Avatar
I had the some of the same problems and I solved all of them by making sure that the star serial connecters were nice and tight. These are the small gray rectanglar connectors located by the bcm in the passenger footwell.
To Door lock problem passenger
