Removing TPS from wheel/tire
Old Jan 28, 2008 | 04:51 PM
jmzvet's Avatar
jmzvet
Default Removing TPS from wheel/tire
Anyway to do it at home without messing up the wheel?
Old Jan 28, 2008 | 05:14 PM
Doug@MorosoPerformance's Avatar
0Doug@MorosoPerformance
Former Vendor
If you have run flats it is just about impossible to remove them with out removing the tire. If you don't have run flats and can break the bead you may be able to depending on the size and stiffness of the side wall.
