How do you change the headlamp bulbs?
Best of luck, have some bandaids handy.
Raise the hood.
from under the hood and iboard of the lights assembly you will see two round ***** covers with rubber boots.
Remove the boots and rotate to raise the headlights manually.
Some will tell you can just turn the key to on, turn on the headlights, back off the switch one click and the headlights will stay up on their own....
That is true..... BUT they forgot to tell you of the auto off feature on the retained power circuit....
Since it is your first time and you will likely be a bit slower at the change out you could end up with your arm still through the side of the headlight assembly when the power cuts out and the headlight lowers
( @#$$%@!%@ ouch)
Once the headlight is up, remove the black plastic bezel, reach in and locate the bulb socket.
You will feel a locking tab that must be depressed (squeezed towards the center) once the tab is depressed rotate the socket out of the housing , remove it, pull the pigtail out thru the opening your arm is in an pull out the bulb.
DO NOT get your finger son the new bulb. The oil on your skin will shorten bulb life.
Reverse the instructions above once you put the new bulb in the socket.
Remove the 3 screws that hold the black plastic bezel from around the head lights
Raise the hood.
( @#$$%@!%@ ouch)
Raise the hood.
( @#$$%@!%@ ouch)
Thanx
The C5 has little metal (aluminium) prongs which hold the socket in place. With large hands and little force they are EASILY bent out of shape.
When I "FINISHED" changing the bulbs I took a drive and saw the lights jittering every time I hit a bump. Tried several times to get the damn sockets seated correctly but NO GO. Finally got the Service Manual out, disassembled the ENTIRE HEADLIGHT HOUSING, and used needle nose pliers to re-form (not BEND - Difference if you FORM the prongs and they DON'T BREAK you have successfully FORMED them. ... If they BREAK then you must have BENT them) the fragile metal prongs which hold the socket.
Unless you have SMALL hands and a LOT of patience, be wary of changing the lamps. A real PITA.
BIGHANK
The bulb can be cleaned with alcohol to remove any oils. Just be careful to not retouch the bulb surface after cleaning.
Learned this the hard way.
I'm glad the headlights did not close on their own with my hand in there. i did not know that would happen! Got lucky on that one.
