Maf Malfunction
Old Jan 29, 2008 | 06:43 PM
Rconce01's Avatar
Rconce01
Default Maf Malfunction
can a MAF cause idle hesistation / misfire without trigering codes on a C5? ALSO MISFIRE UNDER MODERATE ACCELERATION WHICH COMES AND GOES
Old Jan 29, 2008 | 06:47 PM
Oldvetter's Avatar
Oldvetter
Maybe, do you by chance use an oiled cloth air filter (like a K&N) ? Isee you do, as you have a VARARAM INTAKE If so, get some MAF sensor cleaner and clean your MAF sensor.
But if the MAF sensor displays readings that are "outside" normal, it will set codes.
Old Jan 29, 2008 | 06:59 PM
Rconce01's Avatar
Rconce01
No Oil On It Its A Dry Filter. Never Had An Issue In 2 Yrs With Varaam System. With The Maf Disconnected It Runs Awesome But Shifted Hard And Wastes A Hell Lot Of Gas
Old Jan 29, 2008 | 07:06 PM
BlackZ06's Avatar
BlackZ06
Check for leaks between the MAF and the Throttle Body. If air is leaking in, the MAF is not "reading" it, and it will cause the engine to stumble.
Old Jan 29, 2008 | 07:22 PM
Rconce01's Avatar
Rconce01
will do but its all got red silicone couplers with clamps, maybe the air bridge cracked. but its giving no codes and its eradic it will come and go
Old Jan 29, 2008 | 08:17 PM
Oldvetter's Avatar
Oldvetter
When you disconnected your MAF sensor it should have thrown a code. When it throws this code, the computer sets a "safe" (i.e. rich) fuel mixture, hence the excessive fuel use.
Do you have a C5 buddy that you can switch MAF Sensor with?
Whoa, just saw "eratic and it will come and go". Needless to say these are the hardest problems to find. Cycle and clean the connector, a lot of times they are the problem.
To Maf Malfunction
