parking brake adjustment
Old Jan 29, 2008 | 11:37 PM
RED95CONVLUVER's Avatar
RED95CONVLUVER
Default parking brake adjustment
On my 2000 vert my parking brake needs tightened. How is this done?
Old Jan 30, 2008 | 11:54 AM
BlackZ06's Avatar
BlackZ06
There are two adjustments for the parking brake. One is supposed to be automatic, it is part of the parking brake handle, and is supposed to adjust for slack in the cable from the handle to the actual rear drum shoes. The other is an adjustment for wear in the brake shoes in the parking brake. It requires removing the rear calipers to make the adjustment.
For instructions for both procedures, see here .....
http://www.ronjpics.com/Corvettestuff.htm#parkbrake
I'd check the parking brake handle first, as that is somewhat easier to do. If that doesn't fix it, you'll have to go into the rear brakes.
Old Jan 30, 2008 | 03:22 PM
davidfarmer's Avatar
davidfarmer
there is a slot for adjusting the rear drums, just like almost any drum brake setup. You need to tighten both rear adjuster a few clicks.
The handle adjustment (jerking it up several times) simply evens the slack from side to side....it doesn't actually tighten the shoes.
If there is a chance your car has been driven much with the brake engaged, you may need to pull the rear rotors and install new shoes.
Old Jan 30, 2008 | 04:13 PM
RED95CONVLUVER
thanks, ill check the rear drum adjust this weekend
To parking brake adjustment
