from what i have read some bolt them up and have no issues and others needed to run a spacer in the rear to avoid rubbing on the inside. the offsets are different on the c6's so you may need to run a spacer on the rear. i had c6 wheels in c5 offsets and loved them.
you can order aftermarket C6 wheels with the bolt pattern of the C5 and just save yourself the headache.. thats what my buddy did with his 02 SS camaro.. he went with 17s and they worked good
No problem here with the C6 Z06 replicas 19x11 and 18x9.5:
Thanks,Matt
replicas are not c6 offsets they are c5 offsets
If you take OEM c6 rims you will need .25 inch spacer on the rear if you are comfortable with spacers.
Oem c6 rims are only chrome on the face of the star. After market reproductions will be chrome inside the dish as well however a couple pounds heavier.
Miaugi,
First, I would not recommend a spacer. Either use an adapter or purchase heavier knock-offs with C-5 offsets. If the wheels have a 16 mm higher offset, with a 12.7 mm wider wheel, a 6.35 mm spacer will still have that sucked in look at the rear. There are members here that have purchased OEM C6 wheels and used a 1" adapter. Let me know and I will send you photos. Cheers,
