may sound dumb but...
My 97 looks lower in the rear then I see other C5's at. If I get under it, what should I look for on the springs? the bolts? how many threads should stock settings be?
I ask because I went over a speed bump and heard a clunk as if the rear bottomed out a tad- I didn't hit it that hard, but it should not have made the bottom out noise...
Thanks in advance!
Thanks in advance!
Easist way to tell if are lowered is to check the rear bolts and see if they are are just floating in their or that there is some tension on them.
The less thread showing at the top, the higher the car will stand in the rear.
Loosen the nuts to lower. If you have less threads visible above the nut, then the car will be lower.
If you want to raise the rear ride height, tighten up the nuts on the rear bolts (which would leave more visible threads above the nut).
The fiberglass springs on these cars are known to sag and drop the car over time. Your car may very well sit a little lower no than it did new. If you tighten up the rear adjusting nuts, and the height is still too low, you could always install some shorter bolts to give you more adjustment range.
You should always measure from the frame to check height as the fenders may not be hung evenly.
