Cloolant temp XXX ??????
Old Feb 2, 2008 | 01:18 PM
STEEL's Avatar
STEEL
Default Cloolant temp XXX ??????
I pulled my coolant temperature sensor to check if my fans would come on, then I put it back on and now the coolant temp on the screen has three XXX going across, and the coolant gauge is pegged at 260. I made sure it was on tight, and I also disconnected the battery to see if it would return to normal but it didn’t. Do I need a new sensor???
Old Feb 2, 2008 | 01:20 PM
vincentjames501's Avatar
vincentjames501
More than likely. You did plug it back in right? When mine broke I had trouble starting because it threw codes. You having the same problems?
Old Feb 2, 2008 | 01:29 PM
STEEL's Avatar
STEEL
It did struggle to start at first. It also sounds like its not idling as smooth
Old Feb 2, 2008 | 01:33 PM
STEEL's Avatar
STEEL
do you think its broken
Old Feb 2, 2008 | 02:03 PM
BlackZ06's Avatar
BlackZ06
Yeah, sounds broke to me. Three things when you install the new one ...
1) Tighten to 13 lb/ft torque (over tightening can break it)
2) Handle with care, they are sensitive to things like being dropped.
Be certain electrical connection is clean (no corrosion)
Old Feb 2, 2008 | 03:00 PM
STEEL's Avatar
STEEL
how do you tighten it I thought it was just a plug, the one by the alternator and the spark plug??
Old Feb 2, 2008 | 03:36 PM
Slick Rick's Avatar
Slick Rick
If you broke the plug or connecter, youll have to remove the sensor from the block and replace with a new one......
Old Feb 2, 2008 | 03:38 PM
BlackZ06's Avatar
BlackZ06
The sensor is screwed into the left side cylinder head, by the alternator and the #1 spark plug wire. It has a couple of electrical connectors (GROUND and SIGNAL) that the wiring harness from the car plugs into with a single connector. It sounds like all you did was disconnect the wiring from the sensor ... you didn't "pull" the sensor, you disconnected it. The sensor stayed in the engine.
Sounds like you have not got the connector into its matching connector on the sensor correctly. Or you may have damaged the connector when taking it apart. Carefully inspect the connector on the wiring harness and on the sensor. They should fit together without having to force them. Try turning the connector by 180 degrees if it doesn't seem to fit ... you may have it "upside down" ....
STEEL's Avatar
STEEL
how much do they cost and is it a pain to install a new one??
Old Feb 2, 2008 | 04:03 PM
BlackZ06's Avatar
BlackZ06
Did you damage the electrical connector on the sensor ?? If you didn't remove the sensor, then the sensor itself should be fine. If you damaged the sensor then you will need to remove it.
It's not hard to do, but you will have coolant running out when you remove the sensor unless you pre-drain the radiator (which is what the service manual specifies). Then using a socket wrench you unscrew the sensor. Coat the threads of the new sensor with a sealer (GM part number 12346004) and HAND start it back into the engine head. DO NOT USE THE WRENCH TO START IT. If you cross thread the sensor you will have made a real mess of it, so again, HAND START IT. Once the sensor is easily screwing in, use the socket on a torque wrench to tighten to 13 lb/ft. Again DO NOT OVERTIGHTEN.
Attach wiring from the harness, refill the cooling system with fresh coolant, purge air from the cooling system and then you are done.
Part number from GM is 15326388 and list price is $33.95
To Cloolant temp XXX ??????
