0803 Code... help
Old Feb 2, 2008 | 07:12 PM
veni vidi vert's Avatar
veni vidi vert
Default 0803 Code... help
I've reset, but it keeps popping up..
the check engine light is hard for me to look at...
any ideas? All I've done so far is to tighten my gas cap, and to remove and re-assemble my skip shift device..
Help.
Old Feb 2, 2008 | 10:59 PM
87SAM's Avatar
87SAM
If I am reading correctly, you have since removed the CAGS eliminator and set it back up as original? The reason I ask is because I have read of the CAGS resistor going bad.
Old Feb 2, 2008 | 11:02 PM
Bill Dearborn's Avatar
Bill Dearborn
Is there a character in front of the number? What year car?
Bill
Old Feb 2, 2008 | 11:14 PM
87SAM's Avatar
87SAM
Bill
Yes, I just took a SWAG that it was a P0803 because he mentioned the skip shift.
Old Feb 3, 2008 | 01:58 PM
veni vidi vert
Thanks for the responses.
It's an '01 Vert.
the code is 10 PCM P0803 H C.
I currently had the skip shift device installed. I had re-installed it earlier hoping I just hadn't clicked it in good the first time...
Old Feb 3, 2008 | 05:51 PM
87SAM's Avatar
87SAM
I would hook it back up as original to see if there might not be a problem with the CAGS eliminator you have.
Old Feb 6, 2008 | 09:51 AM
z06inVB's Avatar
z06inVB
I had a P0803C code come up yesterday. Pulled the CAGS bypass and the resistor is fried.
Old Feb 7, 2008 | 06:18 PM
veni vidi vert
No code with this setup. I guess it's a bad CAGS eliminator.. Uuugh, this things only about 2 months old... Still I guess it's better than something more expensive being no bueno..
Old Feb 10, 2008 | 12:58 AM
z06inVB's Avatar
z06inVB
I popped mine out yesterday and dug out the sealant to get to the resistor and sure enough it was gone. I got a pack of 5 2.2k .5w resistors from Radio Shack and soldered one on and resealed it. Plugged it back in, cleared the code...problem solved. Total cost $ 1.07 and about 1/2 hour.
To 0803 Code... help
