Changing exhaust on a C5 automatic
Old Dec 2, 2001 | 02:13 PM
VG's Avatar
VG
Virtual George
Navy
Default Changing exhaust on a C5 automatic
Has anyone ever changed the exhaust on a 2000 C5 automatic? I trying to replace my stock exhaust with a set from a Z06. It's going ok, until I tried to remove the right side. I can not figure out how to get it out. I figure it's because of the automatic. Every example I read was for a 6-speed. I did drop the sway bar. I have turned it every way that I can and it does not appear to be possiable. Any great words of wisdom here??
Old Dec 2, 2001 | 03:15 PM
MYY2KVET's Avatar
MYY2KVET
Default Re: Changing exhaust on a C5 automatic (VG)
Well I changed mine on on 2000 automatic to the same exhaust... It was not easy, especially since I am a home gargae kind of guy...
Getting the car off the ground with enough room under is key... I spent hours trying to wiggle it out as you describe with no luck until I increased the height under the car... Not sure how far raised I had the car but I recall seeing a few other related posts where they suggest a minimum of 40", well beyond most standard floor jacks...
Bottom line once it was up high enough the job managed to be easier. Even after all this it still required a good deal of trying, twisting, and turning...
Many folks have just cut the exhaust with a cutter and removed it this way. I wanted to save my original so I went the hard way. Turns out cutting might have been a good option since replacement stock exhausts are relatively cheap (even seen a few foks offering to give them away).
Not sure if that is a clear answer but I suspect your issue may be raised height.
Old Dec 2, 2001 | 03:22 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Mine was done on a drive on type lift. A bar was placed under the frame while the car was slightly lowered to allow the suspension to drop a few inches. On the ground or at home its almost impossible.
[Modified by wallstAL, 1:15 PM 12/2/2001]
Old Dec 2, 2001 | 05:48 PM
VG's Avatar
VG
Virtual George
Navy
Thanks for the replys. I got it done. The trick was to remove the heat shield for the fuel tank. After that it was easy.
Now on to the X-pipe.
Old Dec 2, 2001 | 06:20 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
:cheers:
Old Dec 2, 2001 | 07:15 PM
Mag Red Monster's Avatar
Mag Red Monster
Elite Member
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Glad you found the trick. I didn't read the directions that came with my Corsa's :smash: and ended up taking a chopper gun to the exhaust :(
To Changing exhaust on a C5 automatic
