bleed clutch
Old Feb 4, 2008 | 04:15 PM
jetmech09's Avatar
jetmech09
Default bleed clutch
what is the best way to bleed the clutch master cylinder and slave?
Old Feb 4, 2008 | 05:22 PM
SUPERCRUZ's Avatar
SUPERCRUZ
From what I have read, bleeding the clutch master and slave on a C5 is a royal PIA. Accessing the bleeder is the problem and to get to it you must drop a portion of center exhuast. Your best bet is to use the Ranger method of changing clutch fluid. If you ever have a new clutch installed, get a remote bleeder installed at the same time to make the process easier in the future. Good luck with it.
Old Feb 4, 2008 | 06:32 PM
jetmech09's Avatar
jetmech09
ok thanks
Old Feb 4, 2008 | 08:07 PM
Patches's Avatar
Patches
Since you asked how . . .
http://97vette.com/howto/clutchbleed/index.html
Old Feb 4, 2008 | 08:13 PM
see5's Avatar
see5
Before you go to all that trouble go to Harbor Freight or the like and get a Mityvac. It is much easier and works great.
http://performanceworks1.com/ls1_clutch_bleeding.htm
To bleed clutch
