Oh No! it happened again :-(
Old Feb 6, 2008 | 05:04 PM
Bill Tompley's Avatar
Bill Tompley
Default Oh No! it happened again :-(
Turn on ignition key (nothing).
I had this occasional problem a few months back so I did the following,
- Bypassed the clutch interlock
Still not working
- Checked out the starter relay (relay OK but car not starting)
- Installed a new battery
Still not working
- Installed a new starter
Works great !
3 weeks go by and no problems. Until today (same problem)
What else can I fix/replace?
Maybe I have a short in the ignition switch?
Thanks for your advise,
Bill
Old Feb 6, 2008 | 05:29 PM
BlackZ06's Avatar
BlackZ06
Bill,
What is the status of the SECURITY lamp when you turn the key to the ON position ???
Do you hear any relays click when you turn the key to start ??
Have you checked to see if there are any DTC posted that may inhibit starting ???
Old Feb 6, 2008 | 05:30 PM
big red vette's Avatar
big red vette
might want to try cleaning the pellet on your key
Old Feb 6, 2008 | 06:02 PM
motogib1's Avatar
motogib1
I had a similar situation many years ago on a firebird formula. Every now and then I would go to start the car and nothing would happen. In my case it was static electricity building up in the key. If the security module don't recognize the chip, it ain't gonna start.
Old Feb 6, 2008 | 06:08 PM
lucky131969's Avatar
lucky131969
Still not working
Still not working
Works great !
Bill
I recommend getting a hold of a service manual and troubleshooting the system instead of changing more parts.
Old Feb 6, 2008 | 09:08 PM
mitchcole's Avatar
mitchcole
If you can hear the relay in the passenger footwell going off when you turn the key (get a friend), then you have power going to the starter.
I'm suspecting that the starter you picked up may be faulty.
Old Feb 7, 2008 | 09:05 AM
Bill Tompley
Answers to questions:
Security lamp appear normal
All dash lights/guages appear normal
Relay clicks
No error codes on the DIC
Everything seems normal but
when I turn the key 'nothing'...
Coule be a static problem (I guess).
After waiting several minutes and retrying several times,
eventually it works.
Haven't tried cleaning the key pellet. It looks OK
but I'll give it a try.
Old Feb 7, 2008 | 12:12 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
About the "security" light, is it flashing or on steady?
Flashing is bad and means the BCM doesn't recognize the key, on steady is what it should be doing.
Old Feb 7, 2008 | 12:16 PM
Bill Tompley
The next time it happens I'll double check the Security light.
The problem is everything works OK for several weeks, then
without warning the problem will occur.
I cleaned the key 'pellet' - maybe that will help.
THANKS for all the suggestions,
Bill
Old Feb 7, 2008 | 09:54 PM
falcon5619's Avatar
falcon5619
I had the same problem. I replaced the starter and Theft Deterent Relay and has not happed since.
Old Feb 8, 2008 | 08:37 AM
Bill Tompley
Theft Deterent Relay? What the heck is that and where is it at?
Since I've changed just about everything you can possible change
I guess I'll change that part as well.
Old Feb 8, 2008 | 08:52 AM
falcon5619's Avatar
falcon5619
Others may chime in with more detail...the TDR is located on the passenger side floorboard. When you press the clutch in all the way during starting you should here a click down near the passenger side footboard. This is just one of the relays involved in the starting process. While troubleshooting I learned that this is a relatively inexpensive part that could be replaced to alleiviate the problem. If the TDR is not functioning properly you will not hear the click, which in turn will not send the signal to the starter.
If the TDR is ok, it may be that you actually have another bad starter. Sometimes, the solenoid can be bad, which will cause the same issue you are describing. When it doesn't start listen for the click down on the passenger side footboard.
Old Feb 8, 2008 | 08:53 AM
BlackZ06's Avatar
BlackZ06
You need to stop throwing parts at this issue and diagnose the problem. Next time you try to start the car, look at the following ...
With the key in the ignition, and the lock in the OFF position, what is the status of the SECURITY lamp ??? When the ignition is OFF the SECURITY lamp shows the status of the "Content Theft Deterrent" (CTD) system, which is the system that will "alarm" if a door is opened, for example, without the key or fob unlocking it. The CTD will, in "alarm" mode, disable engine start.
With the key in the ignition, and turned to the ON position, what is the status of the SECURITY lamp ??? In the ON position the SECURITY lamp shows the status of the Vehicle Theft Deterrent (VTD) system. If, for example, the resistance of the VATS pellet in the key does not match what the BCM is programmed for, the BCM will inhibit engine start.
Using the SECURITY lamp and DTC data, we can start to narrow down where the problem is. Generally a wiring problem (bad ground, bad contacts) will cause a no-start with no other symptoms (no DTC data) while a problem with, for example, reading the correct resistance in the key will usually set a DTC.
Use this link to check for DTC data ...
https://www.corvetteforum.com/techti...D=26&TopicID=1
Old Feb 8, 2008 | 09:20 AM
Bill Tompley
You’re right Stephen,
I’m thru replacing parts until I can diagnose the problem.
The next time I have this problem:
- Check the SECURITY lamp condition
(lamp on-OK) (lamp blinking-possible vats pellet problem)
- If the Security lamp is OK
(check for DCTs)
If I have an intermittent VATS pellet problem how should I proceed?
Thanks for the info ...
Old Feb 8, 2008 | 09:55 AM
Bill Tompley
Stephen,
When you say 'bad ground or bad contacts"
What do you mean - exactly?
Bad ground = bad battery ground connection?
Bad contacts = ?
Old Feb 8, 2008 | 11:41 AM
BlackZ06's Avatar
BlackZ06
(check for DCTs)
The SECURITY lamp should be OFF when the key is in the ignition in the OFF position. It should also be OFF when the key is in the ON position. If the SECURITY lamp is on or blinking in either position, that indicates that the car's CTD/VTD system are most likely the problem. Use the link I posted above to see if a DTC is set, usually the security system (especially the VTD system) will post a DTC if the system is activated. CHECK FOR A DTC(s)
Stephen,
Bad contacts = ?
Bad ground is just that, some part of the grounding system isn't working properly. Since our cars have basically a "plastic" body, all electrical systems have to be grounded to the chassis. These "ground points" are prone to corrosion, and when they corrode, the system grounded at that point ceases to work, or works intermittently. See Bill Curlee's sticky at the top of the TECH section for more information.
A bad contact may be something as simple as the wiring to the starter motor. I believe in an earlier post you said the starter was replaced. Check and be sure that the wiring to the starter has not come loose. Be careful, disconnect the battery before working on the starter wiring.
Old Feb 8, 2008 | 11:55 AM
Bill Tompley
Well, my problem is intermittent so now it's working
and the Security lamp is off (both) with the key off and on.
I checked for DCTs - I have 3
10-PCM
P1631 H
40-BCM
B2723 H
A6-SCM
B2607 H
I'll try to look these up
THANKS
To Oh No! it happened again :-(
Old Feb 8, 2008 | 12:01 PM
TylerZ06's Avatar
TylerZ06
I had the same problem and I just unplugged the clutch saftey switch and the plugged it back in and no problem since.
Old Feb 8, 2008 | 12:51 PM
Bill Tompley
Yes Keith,
That's the TDR.
I bypassed that to eliminate that as a possibility.
Old Feb 8, 2008 | 01:13 PM
Bill Tompley
I checked my DTC codes:
10-PCM
P1631 Theft Deterrent System password Incorrect-C
40-BCM
B2723 PASS-Key Detection Circuit
A6-SCM
B2607 Seat Horizontal Position Sensor Failure
Not concerned about A6-SCM but the other two DTCs
probably explain my intermittent starting problem.
Now what to do about it?
Stephen mentioned 'bad ground'.
I'll review Forum posts and try to locate the grounding areas
I need to check out.
What else could cause a 10-PCM P1631 and a 40-BCM B2723?
Thanks for the suggestions
