Passenger side diff shaft R&R
Old Feb 6, 2008 | 06:02 PM
Z06PSI's Avatar
Z06PSI
St. Jude Donor '17-'18-'19
Default Passenger side diff shaft R&R
Anybody have a write up? I have searched this and other forums and cannot find it anywhere. This request is for the actual shaft replacement not the diff removal. TIA
Old Feb 6, 2008 | 06:09 PM
lucky131969's Avatar
lucky131969
Still not clear....output shaft or halfshaft?
Old Feb 6, 2008 | 06:49 PM
zbc51's Avatar
zbc51
any one?
Old Feb 6, 2008 | 07:14 PM
Z06PSI's Avatar
Z06PSI
output shaft....sorry about that.
Old Feb 7, 2008 | 12:09 PM
Z06PSI's Avatar
Z06PSI
nobody?
Old Feb 7, 2008 | 01:34 PM
timemender's Avatar
timemender
Easy straightforward job -
If you are only replacing the differential side seal and not replacing the shaft itself, skip the first two instructions and start with “remove caliper”.
Loosen the outer nut, apply a quality penetrate such as PB Blaster to the shaft spines.
Tap the shaft to insure that it is loose from the outer hub. (Use wood or a brass driver – don’t hit it with a hammer directly)
Remove the caliper (keep hydraulic lines closed) Hang the caliper with an old coat hanger so as to not stress the brake line.
Remove shock from its upper mount.
Remove the two upper inner A-frame mounts from the frame.
Shaft pulls out from the differential with a FIRM tug (or two) once it has room to move.
I will try to locate a pictorial write-up later. Must get back to work now.
Old Feb 7, 2008 | 05:07 PM
Z06PSI's Avatar
Z06PSI
This is for the output shaft out of the differential and not the halfshaft. Sorry if there was any confusion.
Old Feb 7, 2008 | 05:51 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
There is a GREAT writeup with pictures somewhere. Ill see if I can find it
Old Feb 7, 2008 | 06:00 PM
Z06PSI's Avatar
Z06PSI
I have two writeups (MikeMercury and Cajundude) on the Diff pull but none about replacing a shaft on the bench.
To Passenger side diff shaft R&R
