Intake manifold gaskets questions
Old Feb 6, 2008 | 10:11 PM
LCZ06's Avatar
LCZ06
Default Intake manifold gaskets questions
I would like to thank vettenuts for all of his help and ICUALL for the awesome intake removal step-by-step procedure . I wanted to ask those who have removed their intake manifold if it’s ok to reuse the intake manifold gaskets that were replaced not too long ago and if they still look good to everyone else (please see pictures).
The removal was pretty straight forward and easy imop but with a few bumps along the way such as I need to replace one of my manifold bolts because it striped out for some reason. I was able to get the bolt off but I don’t want to reuse the striped bolt. I plan on just picking up another from the hardware store. I’m also pretty sure I have the original oil pressure sensor from 60k miles ago as it’s the brass one and I’m not sure when they replaced the ops with the aluminum ones but it very well could be giving me false oil pressure readings.
Old Feb 6, 2008 | 10:30 PM
randy814u's Avatar
randy814u
I have had my intake off 3 times with the same gaskets, and no problems.
I only reused them after reading how alot of people do that.
Randy
Old Feb 6, 2008 | 10:54 PM
Justin-Sane's Avatar
Justin-Sane
yes, you can reuse them.
Old Feb 6, 2008 | 11:55 PM
1BadLS6's Avatar
1BadLS6
I reused mine with no problems. I just made sure to leave them alone and not remove or mess with em.
To Intake manifold gaskets questions
