Stock Ride Height
Old Feb 7, 2008 | 10:33 AM
byte_me's Avatar
byte_me
Default Stock Ride Height
Can anyone tell me what the stock ride height should be for a 97 (if they are different) front and rear? I believe the previous owner tried to lower at least the rear of my 97 and it sits lower on the rear right then it does on the rear left...I would like to even it out and\or put it back to stock height as it has bottomed out on my on occasion over bumps...don't get me wrong- I like lowered cars, but it is my daily driver and it becomes a hassle when driving on our great south florida construction roads...
I guess I can just tighten the rear bolts back up- but what should the thread count be when doing so?
Old Feb 8, 2008 | 03:27 PM
FKING1's Avatar
FKING1
A search will give you answers.
Old Feb 8, 2008 | 09:42 PM
Tom Porter's Avatar
Tom Porter
My 97 before I lowered it was: (all measurements where taken from the centerline of wheel from floor to bottom edge of fenders)
Front 27 3/8"
Rear 28 5/8"
After lowering with the removal of the front bolts and going with 8" grade #8 bolts in rear (stock are 6").
Front 25 7/8"
Rear 26 1/2"
If you still have the original front and rear bolts, you will have to play with them until you get the height you are after. Mine had about a 5/8" of threads before my changes. This might be a good starting point. I hope this helps!
Old Feb 9, 2008 | 02:34 AM
Bill Dearborn's Avatar
Bill Dearborn
On early C5s trim height could be measured at the control arms or at the frame but in 2001 GM removed the specs for the frame measurement from the manual. Stock ride height is measured from the ground to the frame at 4 locations. Each car has different measurements from ground to fender so they are not used to determine trim height. The frame measurements are called J and K. Here is the spec for base and Z51 and a picture showing where to make the measurement.
For J Trim Height:
Manually push the front of the vehicle down approximately 1 ½ inches. Gently remove hands and let vehicle rise on its own. Repeat two more times for a total of three times.
Measure both the right and left sides of the vehicle.
The True J trim heights are an average of the high and low measurements.
For K Trim Height:
Manually push the rear of the vehicle down approximately 1 ½ inches. Gently remove hands and let vehicle rise on its own. Repeat two more times for a total of three times.
The True K trim heights are an average of the high and low measurements.
Hope this helps.
Bill
Old May 7, 2011 | 04:45 PM
doje's Avatar
doje
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
For J Trim Height:
For K Trim Height:
Hope this helps.
Bill
Are J&K being measured from the actual frame? Or the rocker panel? You say "frame measurements" but GM is calling it "Trim Height". Does anyone know which is right for sure? Also, what is the difference on the chart for "Shipped Height" vs "Curb Height"? Is curb height after the car has had a chance to settle?
Old May 8, 2011 | 09:29 PM
Bill Dearborn
The measurements are taken on the frame not the body. The body panels are just bolted or glued onto the frame and are not the reference.Bill
Old May 8, 2011 | 09:33 PM
doje's Avatar
doje
And "Shiiped Height" vs "Curb Height"?
Old May 11, 2011 | 04:16 PM
Bob25thTA's Avatar
Bob25thTA
Curb I believe is full fluids, gas etc.
Old May 29, 2011 | 08:23 PM
1FUNC5's Avatar
1FUNC5
For J Trim Height:
For K Trim Height:
Hope this helps.
Bill
do I need to use curb weight for a car with a full tank? I am just a hair over 5 inches at those spots on the frame right now. In the process of raising my car to stock height. have 19's and wheel well measurements are 27F / 28R car is a 2004 coupe with stock suspension
To Stock Ride Height
