column lock
You might also want to read this sticky on column lock. It deals with the 3rd recall.
http://forums.corvetteforum.com/show....php?t=1312929
I had column lock on my 99 FRC. Took it to the dealer and had them do this fix. It is a permanent solution because they removed the pin from the locking plate so that the column can never ever lock again. If they do it right you will know because even with key out of car you can turn the steering wheel.
Personally, I believe it is the best way to go.
