were does this connect to
Old Feb 10, 2008 | 05:55 PM
southernshark's Avatar
southernshark
Default were does this connect to
The wiring that leads to the MAP sensor also has a second connector that s purple what does it go back to. I was held up a week on parts and now my memory has failed along with my "put it back together and it will reveal itself method " has failed me. any help would be obviously appreciated. by the way the sensor is almost identical to the map sensor but black w/a purple boot.
Old Feb 10, 2008 | 08:06 PM
southernshark
bump for some help
Old Feb 10, 2008 | 09:17 PM
AMRAAM's Avatar
AMRAAM
I doubt these will help you much since I don;t see the second plug in them, but I thought they might refresh your memory. My car is still apart but I can take a closer look tomorrow if you haven't figured it out.
Could it be for the A.I.R. system?
Old Feb 10, 2008 | 10:39 PM
southernshark
I don’t know if we have the same wiring…I think that 97 is different than the 02 wiring. I do not see the second branch from the map sensor I need to get a picture but I don’t want to walk all the way to the garage as is it too cold right now. The wire seems to want to go naturally to the passenger side but nothing is over there, unless I connects to something behind the intake. By the way I can barley get my hand in the space were you have that camera what do you have the 007 pen camera? I can barely see back there . thanks for the help
Old Feb 10, 2008 | 11:01 PM
AMRAAM's Avatar
AMRAAM
No, no pen camera. If you look closely at the first pic, you can see the rear cyl intake port on the head. I was in the process of removing the intake so it was loose and pulled forward so I could get a shot of how to hook everything back up. Your original question is exactly why I did it
Old Feb 11, 2008 | 12:06 AM
Cscokd's Avatar
Cscokd
If my memory serves me right there are only two things that have electrical connectors back there. Both at the rear of the intake manifold between the heads. The oil pressure sensor towards the driver's side and the MAP sensor towards the passenger side on the intake manifold. There's a small vacuum tube back there as well.
Old Feb 11, 2008 | 08:40 AM
southernshark
YEP AND BOTH ARE HOOKED UP BUT THERE IS A SENSOR THAT IS ON THE SAME (BRANCH,LINE,LIMB) AS THE MAP SENSOR ON MINE AND CAN NOT FIGURE OUT WERE IT GOES.
IF I WAS TO HOOK THE BATTERY UP IT WOULD THROW A CODE….WONDER IF THAT IS MY NEXT STEP?
sorry had caps lock on will not retype
Old Feb 11, 2008 | 09:06 AM
Tim01Coupe's Avatar
Tim01Coupe
I did the same this when I pulled a Quad 4 from my wife's old car. I knew the wire would only reach so far and I literally stretched it out and started going in circles, bringing it in little by little.
Old Feb 11, 2008 | 09:29 AM
lucky131969's Avatar
lucky131969
what color are the wires to the connector and how many pins?
Probably the inline connector for the knock sensor, or the camshaft position sensor. Very well depicted in your service manual.
(1) Engine Oil Pressure (EOP) Sensor
(2) Manifold Absolute Pressure (MAP) Sensor
(3) Camshaft Position (CMP) Sensor
(4) Ground #G107
(5) Connector #C112 - Inline between Engine Harness and Knock Sensor Jumper Harness
Old Feb 11, 2008 | 09:36 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
We need to know the wire colors and the amount of pins coming off the connector.
And of course could use a pic of the loose connector
It can't be too far away, I'm thinking it might go to the fan motor for the AC and Heater blower or perhaps one of the AC sensors. Just a thought!
Let us know as soon as you are able too!
Thanks,Matt
Old Feb 11, 2008 | 09:37 AM
southernshark
3 pins. the pins are just like the map pins except that it is opposite of the map. connector is black, pupple boot, 3 wires connector says 25 ped on it.
Old Feb 11, 2008 | 09:39 AM
lucky131969
http://www.flickr.com/photos/1545929...15988/sizes/l/
Check my post #9 for identifiers
Old Feb 11, 2008 | 11:42 AM
Just Enough's Avatar
Just Enough
I think that's for the knock sensors, the connector is usually clipped to the fuel rail stop plate on the drivers side toward the firewall. The stop plate bolts down when you install the manifold with the manifold bolts.
Old Feb 11, 2008 | 12:57 PM
southernshark
Damn I think it is the #3 in the pic from lucky…time to take the intake back off… we will know tonight
thanks guys
Old Feb 12, 2008 | 09:06 AM
southernshark
fixed it last night. it was the knock sensor don't know why i unplugged that. Thanks to all that helped. yall come down to Springfield and i will buy you a beer.
Old Feb 12, 2008 | 04:33 PM
AMRAAM's Avatar
AMRAAM
On my way!
Glad you got it fixed
Old Feb 12, 2008 | 04:46 PM
lucky131969
Well done sir.....I'll take an ice cold High Life
To were does this connect to
Old Feb 12, 2008 | 05:58 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Only thing back there that I can think of is the oil pressure switch.
Old Feb 12, 2008 | 06:27 PM
lucky131969
Perhaps you should look at post#12
Old Feb 12, 2008 | 06:37 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
I was caught up in something else and just forgot to hit enter, so others posted info up in between my response, excuse me.
