Headlights go down when they feel like it.
Old Feb 10, 2008 | 08:42 PM
johninar's Avatar
johninar
Default Headlights go down when they feel like it.
I installed the high wattage European headlights today. Everything is working just fine. Only problem is when I turn the headlights off, I just hear a click and nothing. I can leave the lights off and wait a few minutes, I can turn the headlights on and off they will lower.
I've double checked the ground and relays. Not sure where else to look.
Ideas?
TIA
Old Feb 11, 2008 | 02:36 PM
AnteVenom's Avatar
AnteVenom
Cruise-In IV Veteran
Daytona Jam 1 Veteran
Not much to go on from your post but I'm thinking it is a problem in the light stalk on the steering column or perhaps even a bad headlight control module located behind the passenger headlight assembly.
I really think it is the latter since I have experience with this going bad and your indication that you can turn lights on/off and get them to go down is what happened for me prior to replacing the control module.
Old Feb 11, 2008 | 07:12 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Are these HID's? If so, they are not high wattage, just high output and there is a difference. If they are HID's, I have seen a technical post in here about putting a resistor in the circuit somewhere. Do a search and you should find it.
Old Feb 11, 2008 | 11:34 PM
johninar's Avatar
johninar
These are PIAA 135w/90w with new harness, relays etc. Purchased from PFYC
http://www.pfyc.com/pc/VT1003/VTLIGH...d+Options.html
I'm sure it's related to the kit install. I've never had a problem before.
To Headlights go down when they feel like it.
