Dumb TPS question for the day
Old Feb 11, 2008 | 11:33 PM
RL Vetteman's Avatar
RL Vetteman
Default Dumb TPS question for the day
I need to replace the battery in my front left tire sensor. I will be trying methods noted on this forum for the battery replacement. My dumb question is: Can I get the sensor off with out removing the tire, i.e. just letting air out of the tire and stepping on the tire while my buddy unscrews the sensor? Oh, I do have enough weight in my "spare tire" to deform the sidewall, like about 300 psi Just trying to save some time from going to the tire store to get the sensor out. Time=$$$
Old Feb 11, 2008 | 11:53 PM
Oldvetter's Avatar
Oldvetter
Low profile tires are hard to change, run flats are VERY hard. I doubt that you can break the bead on them.
Old Feb 11, 2008 | 11:56 PM
countslav's Avatar
countslav
Very Very, hard...
Corvette Don's Avatar
Corvette Don
You will need a machine to de-bead the tire and the battery replacement is not easy at all, you can ruin the sensor if you are not careful
Old Feb 12, 2008 | 12:07 AM
RL Vetteman
Thanks for the quick reply guys, i will get the tires dismounted and remove the sensors at home & replace the batteries. I figure I will give the replacement of the battery a try 1st before I spend the coin on new sensors. I work in the electronics field so if I ruin the circuit board I can probably repair it. It looks like the hard part is the removing the potting and choosing the right epoxy to replace it with.
Old Feb 12, 2008 | 12:19 AM
Corvette Don
I have rebuilt over 150 of these and I can tell you first hand the circuit boards are not fixable, you will ruin the resistors, etc trying to get the epoxy out (but not over the battery). Good luck
Old Feb 12, 2008 | 11:28 AM
myk7's Avatar
myk7
Be sure and replace the O ring.. I believe it's a #9
Old Feb 12, 2008 | 12:09 PM
Russ K's Avatar
Russ K
The grommet is available separately under GM part #25715243.
Russ Kemp
Old Feb 12, 2008 | 12:48 PM
euro@EFIAlchemy.com's Avatar
0euro@EFIAlchemy.com
Former Vendor
Dont really understand this, those circuit boards can be repaired.
Old Feb 12, 2008 | 12:56 PM
jrprich's Avatar
jrprich
If one batterty is dead, the other three are likely about to die as well
Old Feb 12, 2008 | 02:43 PM
Corvette Don
You may be right but its not worth the hassle of tracking down which one of the 100 resistors and elec stuff thats bad.
Old Feb 12, 2008 | 07:42 PM
SLO VETTE's Avatar
SLO VETTE
Didn't you get the memo?
Old Feb 13, 2008 | 03:25 AM
BlackZ06's Avatar
BlackZ06
It may be your terminology, but you don't need to dismount the tires. Dismounting means seperating the wheel and tire completely. All you need is to break the bead from the rim of the tire so you can reach inside the tire to remove the sensor.
If you have compressed air available, you can install the new/repaired sensors and reseat the tires without another trip to the tire shop if they have simply been broken from the bead. Be certain the tire shop that breaks the bead has marked the tire to show where it lines up with, say, the valve stem. This way when you air the tire back up it will be in correct placement with the balance weights on the rim.
Once you have the new TPMS installed (often helps to have a 2nd person available for this) you start blowing compressed air in through the valve stem. As you do this, be certain the tire is correctly oriented on the rim, and by pressing in on the tread area of the tire you should be able to get the bead to settle onto the wheel again. Usually most tire shops air the tire to its MAX rated air pressure (as marked on the sidewall) to ensure the tire has seated properly. Then lower the pressure to the correct amount (30 PSI) and install on the car.
To Dumb TPS question for the day
