In-line Fuel Pump Question
Old Dec 3, 2001 | 06:44 PM
Gus's Avatar
Gus
Cruise-In III Veteran
Default In-line Fuel Pump Question
Does anyone know if an in-line T-Rex fuel pump work on C5's? :confused:
Old Dec 4, 2001 | 03:04 AM
FRPTech's Avatar
FRPTech
Default Re: In-line Fuel Pump Question (Gus)
Gus,
Yes. The high pressure/volume trex pump will work as an inline/"booster" pump.
Here's a write up from awhile back: http://forums.corvetteforum.com/zerothread?id=152762
Be sure to take the time and try to find the nylon hard lines.
I've had to replace the high pressure rubber lines that I used already. They just don't hold up...
FRPTech
Old Dec 4, 2001 | 03:08 PM
Godspeed's Avatar
Godspeed
Senior Member
Cruise-In IV Veteran
Default Re: In-line Fuel Pump Question (FRPTech)
I've had the same problem with the rubber lines. Great right up btw FRPtech! :cheers:
[Modified by Godspeed, 1:08 PM 12/4/2001]
Old Dec 4, 2001 | 07:41 PM
Gus's Avatar
Gus
Where would you find nylon hard lines? Oh BTW, great info FRP Tech!
Old Dec 4, 2001 | 07:51 PM
C5Cemo's Avatar
C5Cemo
FRPTech- Like the others, I am very happy that you shared your install experience with us...great write up!
:cheers:
Old Dec 4, 2001 | 08:21 PM
Paradigm's Avatar
Paradigm
Excellent write up and great info..thanks
Old Dec 4, 2001 | 10:00 PM
FRPTech's Avatar
FRPTech
Gus,
Actually, The local Pep Boys can get them here in CA with the quick-connect fittings already on the one end.
I'm sure any national parts chain can get the hard line with GM quick connect fitting for repair purposes. When I get home tonight, I'll see if I can find my info on the manufacturer...
FRPTech
Old Dec 4, 2001 | 11:13 PM
C5Noir's Avatar
C5Noir
How much were the parts, fuel pump etc for this install? thanks.
Old Dec 5, 2001 | 05:12 AM
FRPTech's Avatar
FRPTech
Gus,
Just to follow-up:
The nylon hard lines are labeled as "GM/Chrysler Nylon Fuel Line Repair Kits" and are made by a company called Dorman. They come in various sizes and I would think just about any national parts chain could get them for you. They are a little pricey about $15 each but I think they are worth it to avoid having to redo the setup as I did because of a ruptured line - I'm sure Godspeed would agree...
C5Noir,
You can probably do it for $225 if you shop around.
Rough estimate on costs: $125-175 for the pump. $30-40 for the hard line, another $10-15 for the fittings, $12 for the thermo blanket, $30 for the filter , $20 for the wire, relay & fuse...
FRPTech
To In-line Fuel Pump Question
